Sponsored by: CARiD
22r timing problem please help!
Old Feb 11, 2009 | 03:46 PM
RustySchackleferd's Avatar
Ok so i have a 22r bought it off some guy on craigslist. He said it ran great ect.... so i get it in my truck turn the key and it fires right up. so i kill it and try one more time. Thats where the trouble starts. Try again and it sounds like its only running on 2 cylinders. so im thinking it is the timing chain. so i go out and get a new one set all my zeros and im at TDC but still the same problem. I have been messing with it for a week now and cannot figure it out. Please help.
Old Feb 11, 2009 | 04:30 PM
yota8083's Avatar
why would you think it would be timing chain if it was missing on two cylinders? If it were me I would have checked the plugs and wires first(not as expensive) and go from there. If the cylinders missfiring are side by side it could be a blown head gasket as well. We need more info to diagnose further.
Thomas
Old Feb 11, 2009 | 04:37 PM
well it isnt the head gasket i just replaced it. and i had replaced the plugs and wires before anything. The compression is good. when ever i try to turn the motor over it will sound like 2 cylinder then it will blow back through the carb. but not a loud backfire or anything. but its all timed right.
Old Feb 11, 2009 | 05:18 PM
Greenlighter's Avatar
You need to do a cylinder leak down test. Good compression doesn't always mean good running motor.
Old Feb 11, 2009 | 07:12 PM
i did that and it was fine
Old Feb 12, 2009 | 05:09 AM
landozion's Avatar
I am certainly no expert, but sounds like your timing chain may have jumped a link, or your distributor may be off a tooth.
Old Feb 12, 2009 | 04:23 PM
well my chain wont line up but i thought it was supposed to be that way. the one that i took out of it did it as well. just never lined up. But it couldnt have jumped its tight on there and i tried toying with the distributer janged it by one tooth and still the same problem
GreenLion
Jun 7, 2021 10:49 AM
Jmiller1023
23
Aug 6, 2015 07:03 PM
bigblue82
10
Jul 6, 2015 08:27 AM
thelifeadventure
Jul 2, 2015 03:09 PM
83flatt
Jul 2, 2015 10:30 AM
