22R/RE differences given it is same year
Old 07-13-2010, 08:24 PM
dc4866's Avatar
Hey guys,
I'm wanting to know if there are any significant differences in the block/head of an 1985 22R vs RE. I have a 22R(85) that I'd like to have rebuilt for use in my 85 4runner. I just have the 22R sitting in the shop and my thought was to have it rebuilt and do the swap in one or two days(while everything is fresh in my mind) vs. waiting several weeks for the motor in my 4runner to be built up. And yes, I tried the search function but didn't find a specific answer to this question. Thanks for your time.
Old 07-13-2010, 08:42 PM
myyota's Avatar
They should both be the same, other than being carbed or fuel injected.
Old 07-13-2010, 09:02 PM
85gijunk4x4's Avatar
everything is the same internally, the only difference is that fuel gets delivered into the cylinders via carbarator as opposed to fuel injectors, i may be wrong, but im pretty sure the valve lash is adjusted diferently
Old 07-14-2010, 05:36 AM
rsidner's Avatar
So you want to put the formerly carbed long block into an EFI 4runner?
I would double check one thing just to confirm. Check to studs on the intake side of the head and confirm there are as many in the same positions for the EFI plenum to mount up. You should be fine though.
Aside from that, you probably do not have a spot for your knock sensor to thread into. You will have to find a good spot on the block, drill a big ass hole and tap it out to match your knock sensor.
That's all I can think of for now but if I can think of something else I'll let you know.
icentropy
09-16-2020 02:47 PM
jasonty
41
12-23-2018 01:00 PM
Amer
3.4 Swaps
19
06-05-2017 10:43 AM
msane99
07-17-2015 10:13 AM
msane99
07-11-2015 08:08 PM
Quick Reply: 22R/RE differences given it is same year
