Sponsored by: CARiD
2 issues on 1980 Pickup
Old Jan 29, 2024 | 03:19 PM
19pickup80's Avatar
Exclamation 2 issues on 1980 Pickup
I inherited my dad's old pickup and have spent all kinds of time getting this thing up and running and have hit another snag. While it is running great now, passed CA smog and everything, I'm getting 2, or 3, minor issues that I don't know how to solve.
The first issue is electrical. The fuse for the windshield wiper keeps blowing and sometimes while I'm driving the tail lights, blinker and all, go out. Then the lights will work again later. Any idea as to what may be causing these issues?
The second is that the RPM tach intermittently works. More often than not it does not work at all. But, occasionally, it'll work perfect. Any suggestions on how to get the tach working permanently?
I appreciate all of the help as I am learning as I go here.
Old Jan 29, 2024 | 05:01 PM
millball's Avatar
Clean and improve all grounding points for starters
Old Jan 30, 2024 | 02:00 PM
2ToyGuy's Avatar
The tail lights develop corrosion on the ground points they use, right behind them. Pull the tail lights off as a unit, one corner at a time, and ensure the grounds are clean and shiney. No corrosion. The ones in back are the worst for the corrosion, but the fronts develop it too.
I don't know right off just where the tach picks up it's ground, but I'd wager that's the problem. Might be it just needs ground strap installed, or repaired, someplace.
Gppd luck to ya!
Pat☺
Old Feb 14, 2024 | 05:56 PM
jeremy harp's Avatar
How did you work it out ?
Old Feb 18, 2024 | 05:22 PM
19pickup80's Avatar
So far, I haven't gotten it working. I cleaned all the connectors up but need to do some more deep cleaning for the tach. Thank you for asking. I'll shoot an update if I get it working properly.
glitchinq
Dec 19, 2016 08:12 AM
Markarino
May 20, 2013 08:21 AM
runt262
Feb 19, 2009 09:50 PM
sirus62
Oct 8, 2007 07:30 PM
Five1Nine8Eight
Feb 2, 2005 01:39 PM
