Sponsored by: CARiD
1994 toyota xcab front hub/wheel bearing bad
Old Aug 18, 2013 | 03:54 PM
jfromtn's Avatar
My son has a 1994 xcab he left a front hub locked in.anyway the bearings went dry and now he needs a new hub and bearings or something like this.im not that mechanical.whatever the assembly is oreillys does not sell.they said we would have to find a used one.what vehicle has the same setup?forerunner same year?
Old Aug 18, 2013 | 04:02 PM
JasonYota's Avatar
Welcome from Alabama.
Leaving the hubs locked in wouldn't cause a wheel bearing to go out. Any parts store should have wheel bearings, you might need a press to get them changed though.
Old Aug 18, 2013 | 04:07 PM
JasonYota's Avatar
Orielly's part numbers
Inner bearing JLM104948
Outer bearing LM102949
There are 2 wheel bearings per side
Old Aug 18, 2013 | 04:26 PM
jfromtn's Avatar
Hey thanks. I'm in tennessee .at work all weekend so I haven't seen the truck but his grandad got someone he knows to work on it.what ever he said it was bad up to the spindle?
Old Aug 18, 2013 | 04:30 PM
JasonYota's Avatar
What is the truck doing? Did the wheel lockup or making noise?
Old Aug 18, 2013 | 05:29 PM
jfromtn's Avatar
I think it's making a lot of noise.father in law said the other side was fine.wish I had more info as I won't be home until tomorrow
Old Aug 18, 2013 | 06:02 PM
rokblok's Avatar
About where in Tenn? I'm located south central, near Pulaski.
Old Aug 18, 2013 | 06:03 PM
jfromtn's Avatar
Lawrenceburg
Old Aug 18, 2013 | 06:10 PM
jfromtn's Avatar
Are the axle parts on the 94 xcab the same as on a forerunner from same year?
rokblok's Avatar
Heck I'm right around the corner. Right on the county line. If you need some help, let me know. I will PM you my cell.
Old Aug 18, 2013 | 06:11 PM
jfromtn's Avatar
Hey thanks
Old Aug 18, 2013 | 06:20 PM
rokblok's Avatar
4runner of same year and drivetrain (4wd) should be the same.
I know you said he left a hub locked in, so I presume it has Aisin manual hubs? Not the ADD(auto differential disconnect[?])? And leaving a hub locked shouldn't cause that severe of a problem. Although it will create more heat, which may have caused the bearing to overheat and fail, if the grease was in bad shape to begin with or non-existent.
Old Aug 18, 2013 | 06:23 PM
jfromtn's Avatar
Yes they are manual hubs. Father in law said the grease was not good.
Old Aug 19, 2013 | 06:15 AM
jfromtn's Avatar
Thank you very much
Crazy_Guy97
12
Jun 24, 2015 04:02 PM
94hiluxZE
Jun 22, 2015 10:42 AM
bobbybouche
Jun 18, 2015 10:22 AM
Old Red 94
Jun 16, 2015 08:32 PM
