Sponsored by: CARiD
1991 Truck Wont Always Start
Old Feb 11, 2010 | 10:16 AM
uplandretriever's Avatar
Question 1991 Truck Wont Always Start
i am new to the form and have done lots of reading. i am having a couple issues and cant seem to figure them out.
1. When you turn the key you can here a click and that is it. truck will not turnover. Keep Clicking a sequence of times and finally the truck will start. When it does start it runs really rough for a minute or two. i have tried the clutch cancel switch when trying to start but this doesn help either. Any Help would be appreciated. After you get it started it might start several times after that. Seems to only do it when the engine is cold or sat for 3-4 hours.
2. E-Brake light stays on and wont go off. i have checked the switch by the E-Brake lever and its good. Also checked the switch on the master cylinder and it acts as its working. But if i unhook the Master Cylinder Switch the light goes off??? Also would this keep my cruise from working?
Old Feb 11, 2010 | 04:44 PM
anybody got any ideas, i dont want to get stranded in this thing.
Old Feb 13, 2010 | 06:06 AM
eddieleephd's Avatar
1. is most likely starter contacts $20.00 at Toyota!!!
2. have you checked your brake fluid level??? cruise may be kept from working due to this or the turn signals or brake lights being out,,or leds being used...
Old Feb 15, 2010 | 05:34 AM
changed the contacts and seems to be better. i unhooked the sensor on the master cylinder and brake light went off. Brake fluid level is good.
Old Feb 15, 2010 | 06:29 AM
would suggest replacing the sensor or cleaning it and it sounds like it will cure the light issue
and you say it seems to be better if not cured you will most likely need to check and clean your grounds, and the starter relay may need to be replaced...
Old Feb 15, 2010 | 06:38 AM
Do you know if you can just buy the sensor or do you have to buy a new reservoir? i have cleaned the grounds to the starter.
Old Feb 15, 2010 | 06:53 AM
not sure I would suggest calling the dealer and asking as well a good resource is
http://www.tacomaterritory.com/wiki/...ma_Information
here are the part numbers gear codes and a bunch of info very nice to have access to
Old Feb 19, 2010 | 08:15 AM
thanks for the help guys. $20 on contacts and a plunger fixed the starting problem.
zd92655
Mar 6, 2022 12:58 PM
Aleeex_u
Jun 5, 2016 06:52 PM
bprice0077
Jun 25, 2015 07:36 AM
slider417
Jun 22, 2015 10:18 AM
ShaunKris
Jun 17, 2015 04:33 PM
