Sponsored by: CARiD
1990 toyota pickup trouble
Old Jul 6, 2012 | 11:32 PM
Chris Lane's Avatar
Hi I have an 1990 toyota pickup.Now the problem i think is that it is not getting fuel,cause it only starts and stays started when it has starting fluid in the throttle body.I have checked the fuel pump,injectors,mass air flow sensor ,fuel lines I even jumped the obd port and no codes came up so any help would be nice.
Old Jul 7, 2012 | 12:06 AM
combatcarl's Avatar
uhhm... it won't run without the intake connected to the VAFM on top of the air box. Unless you have better juju than I do.
Old Jul 7, 2012 | 12:08 AM
wyoming9's Avatar
Talking
Just how are you getting starting fluid in the throttle body??
If you have the intake disconnected you have no air flow closing the switch in the AFM to turn the fuel pump on.
Just how did you check the fuel pump and who`s Mass Airflow sensor did you check
Did you maybe run out of gas??
Old Jul 14, 2012 | 04:43 PM
jharriet's Avatar
i have the same problem.. very same did you end up finding out what was wrong?
6th Gear
19
Dec 10, 2019 07:31 AM
Weidle
Jan 21, 2019 05:39 AM
Aleeex_u
Jun 5, 2016 06:52 PM
GorgeRunner
Jun 27, 2015 07:01 AM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
