1988 toyota 3.0 V6 help please
Old 03-10-2009, 09:47 AM
motorhead2u's Avatar
getting a 1988 toyota pickup had fuel pump problem the guy said that the fuel pump went out. I fixed that and the truck still would not start so figured it was the battery so I replaced that and it still does not run when the egnition is turned it clicks but motor does not turn over Please help any input is much aprisheated.
Old 03-10-2009, 10:50 AM
Innervision's Avatar
check the starter connections. Do you get one click and nothing or is it a series of clicks? Sounds like it the starter is not engaging. The motor does not crank correct?
Also make sure you have a good connection at the battery.
Old 03-10-2009, 12:09 PM
yes it clicks once and stops and no it does not turn over so starter problem
Old 03-10-2009, 12:12 PM
DC Hoerunner's Avatar
did you check all the fuses inside and under hood?
Old 03-10-2009, 12:58 PM
yes all the fuses are good in cab and under hood
Old 03-10-2009, 01:50 PM
toyota4x4907's Avatar
Starter. Replace the contacts or replace the starter.
Old 03-14-2009, 12:24 PM
that all taken care of there was a short but new problem it starts and idols and but it will not drive in 2wd it will only in 4-low not enough power did the trouble engine light code and it is
MANIFOLD AND/OR AIRFLOW METER SENSOR SIGNAL CIRCUIT --AIRFLOW METER/CIRCUIT
--MANIFOLD PRESSURE SENSOR/CIRCUIT
--ECU
what would likly cause this. I think it is a compression issue went to check for spark but the spark plugs were only finger tight tightend him down and it started running better but it is a mistery to me
Charecter1
11-06-2023 10:08 AM
mskalmus
05-28-2017 07:51 AM
MTLroadierunner
07-15-2015 12:58 PM
andrewtexas123
07-14-2015 04:29 AM
Quick Reply: 1988 toyota 3.0 V6 help please
