Sponsored by: CARiD
1988 3.0 motor swap into 1994 toyota pickup
Old Apr 27, 2011 | 03:10 PM
tacoma83's Avatar
i took the motor out of a 1988 toyota pickup 4x4 ex cab and put it into my 1994 toyota pickup ex cab 4x4. we used the wirering from my 1994 so we had to mod some stuff, like the injectors i didnt want to swap them so i just shaved alittle off the conector with a razor blade they fit right on now. destributor we dicided to cut off the conector on the wirering harness and put the 1988 conector on wires were the same color. the coil wire needed to have the end swapd to then not a big deal, did that. ok so the motor ran b4 we swaped. then we got it to start, it ran rough we adjusted the timing alittle it was better, but still not right so i put new plugs in it, took it for a test drive thinking it just needed to run it had been sitting for a year or 2. got about a mile died. turned over but wouldnt start. figured it had to be fuel so replaced the filter...its getting gas and spark now starts for a sec or 2 and dies....any ideas?? thank you
Old Apr 28, 2011 | 04:43 AM
rattlewagon's Avatar
Compression?
Did you adjust the valves?
You said its getting fuel and spark...what about air?
Old Apr 28, 2011 | 09:54 AM
tacoma83's Avatar
Didn't do a compression check but I can..no didn't adjust the valves..I have the air cleaner hose off so yea I think its getting air. All doo a compresion check this weekend
Old Apr 28, 2011 | 11:48 AM
jrobertson4runnner's Avatar
If you don't have any air going through the VAFM or MAF, whichever you have, the truck won't run at all. found that out with a lot of my friends in the truck, wheelin a bit, and it popped off. at the block. put it back on and presto.
Old Apr 28, 2011 | 06:14 PM
tacoma83's Avatar
Do u know where those would be located on the block? And what to look for?
vasinvictor
Jan 20, 2016 12:39 PM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
94hiluxZE
Jun 22, 2015 10:42 AM
nyk08trx
Jun 18, 2015 09:01 PM
infinityisfive
Jun 16, 2015 06:51 PM
