Sponsored by: CARiD
1986 toyota wont start no electricity
Old Dec 5, 2010 | 06:38 AM
heatt69's Avatar
I have a new battery just replaced it because I let my 4runner 22re sit for a few months..it was under warranty so I said why not get a new one...Now Its completely dead nothing, no light no clicks no anything...All fuses look good cables looks ok...Any ideas what else could cause O power as if u had no battery in? My fog lights work that r hooked straight to battery but thats it....
Old Dec 5, 2010 | 11:49 AM
James Woods's Avatar
Sounds like a positive cable problem to me, are you sure the positive terminal end isn't cracked or broken? After we bought my wife's 4runner this same thing happened, I checked both cable ends both seemed tight, removed them to clean and found one cracked, I replaced it and no more problems.
Old Dec 5, 2010 | 01:59 PM
heatt69's Avatar
NO i havent taken off the cables, I guess I should just to make sure...If anyone has any other ideas what could cause o power let me know thanks
Old Dec 5, 2010 | 02:23 PM
matstaley's Avatar
There is a fat white wire that goes from the positive terminal to the fuse box in the engine bay. Check that for a fusible link. Mine went bad the other day while i was installing some fog lights. It took me a little while to figure it out. check for power inside that fuse box
Old Dec 5, 2010 | 04:44 PM
heatt69's Avatar
wow ok I did see a wire that someone extended with red and at the bottom its white, couldnt find any area it went to cause it so short...I would guess thats it but I have no fusible link to it, or know just what spot it goes to..It had just a bare end to it so I took it off thinkin someone had it hooked to something they had in the past...Yes no power to any fuses...does it hook under the box and do u know to witch spot...thanks alot
Old Dec 5, 2010 | 04:55 PM
heatt69's Avatar
If that is it, they had it hooked driect to the box with no fusible link to it..Just stuffed under the box some place I asume...If this is it, witch I wont be able to check till tomorrow in the light, u saved me alot of work and headache bro....Now I just need to get the right set up and put it back the way it should be not half assed, like they had it and find out where it goes forsure...Did I say its an 1987 toyota 4runner with a 22re 5 speed...Would guess the set ups on truck and runners r all the same?
Old Dec 5, 2010 | 04:57 PM
heatt69's Avatar
opps maybe its an 86 not 87
Old Dec 5, 2010 | 06:23 PM
matstaley's Avatar
should be the same. it goes directly into the bottom of that box. I don't have a fusible link in mine either. just a solder joint where the black tape is. I had to repair a loose crimp connector that the previous owner had put on. Here is another picture of it.
Old Dec 6, 2010 | 02:51 AM
heatt69's Avatar
Looks like I have a few spots under their it could go...Do u know if it goes to the 80 amp fuse? thanks
Old Dec 6, 2010 | 07:03 AM
matstaley's Avatar
I believe it feeds that 80 amp fuse, yes. there is no single accessory that would use that much current on its own. that fuse should feed the rest of the smaller fuses. it could be that there never was a fusible link and that 80 amp is used instead.
Old Dec 6, 2010 | 08:20 AM
heatt69's Avatar
ok thanks
Old Dec 6, 2010 | 01:55 PM
matstaley's Avatar
The fuse marked AM1 is actually your fusible link according to the FSM for 1985.
Old Dec 6, 2010 | 03:26 PM
Many Toyotas's Avatar
Thumbs up 86 toyota won't start no electricity
Had the same problem with my last 87 pickup, It is almost always the fusible link !!! You can pick up replacements at any NAPA !!!
Old Dec 6, 2010 | 04:37 PM
heatt69's Avatar
Am1 I will have to check it out...I still havent been able to look at it yet been bad weather...I know thats it, after talkin with u...
Old Dec 6, 2010 | 05:44 PM
matstaley's Avatar
Yep. I just worked on mine last weekend.
Old Dec 6, 2010 | 06:20 PM
Pool Playen Bob's Avatar
first wheeling trip i yanked mine out of that box. same day i found out i didn't have a battery tie down strap.
half way through a trail the battery bounced out and pulled it out. but a good to know thing.
Old Dec 7, 2010 | 01:48 PM
heatt69's Avatar
ya forsure good to know thing
Old Dec 8, 2010 | 10:10 PM
heatt69's Avatar
Thanks alot for everyone who helped!!!!!!
Old Dec 9, 2010 | 03:19 PM
thspittingllama's Avatar
if that doesnt work... just check all conections to and from the batt. if you know how to use a test light or a volt meter that would help too. just follow the major wires/ conections from the batterie.
Old Jan 2, 2011 | 01:16 PM
heatt69's Avatar
does anyone have a pic of the bottom of that fuse box?
