Sponsored by: CARiD
1000rpm idle surge caused from brake lights
Old Mar 20, 2015 | 09:13 PM
1986yota's Avatar
My 1986 4x4 pick up 22re is having a surging problem caused by the brake lights when idling at 1000rpm or more. I held the brake switch down and pressed the brakes to rule out a vacuum problem so I know it's the brake lights but Idk how to fix it. Can any of y'all help me?
Old Jun 20, 2015 | 11:38 AM
naward1996's Avatar
Mine used to surge when the temp got cold and I pressed the brakes, I searched everywhere and never had any luck... As I was coming home from work in December, I ran the truck up about 5500 rpm and it hasn't done it since, never figured it out, but I home that helps you some man
Old Jun 20, 2015 | 12:28 PM
millball's Avatar
Clean all your engine and body grounding points, add a couple more while you're at it.
Old Jun 20, 2015 | 03:40 PM
ItsAtoyotaLIFE's Avatar
drivers brake light and fuse
iv got somewhat the same problem mine will do fine till I put in a light on the drivers brake light then as soon as I go above a idel it pops the fuse and takes out my dash and driving lights any ideas?
smthwsn357
May 1, 2024 07:28 AM
ashersullivan88yota
Jan 18, 2022 05:37 PM
Sleaker
Aug 26, 2020 06:03 AM
Sandman
Jul 14, 2015 12:36 PM
Johntom240
7
Jul 13, 2015 12:18 AM
