Items Wanted Vehicle and non vehicle related
WTB[PacSoWest]: Body Mount Bolts - '86 4Runner
Old Nov 28, 2013 | 11:37 PM
buickid's Avatar
Hello all, looking for all or at least the rear 6 body mount bolts for a 1st gen 4Runner. The front 4 are available from Toyota, but the rear most ones with the large washer on the head (with what appears to be a tab) are not. Need these to undo the body lift for my daily/resto project. I don't even need the nuts, I have replacement ones, if you want to just throw everything in a box, thats fine too, I'll sort it out. Bolts should be in fairly good, usuable condition or better. I'll pay anything reasonable plus shipping, so if you've got em lying around from a bodylift, let me know. They should fit in a small flatrate box. PMs work fine, I check them often.
Thanks!
Old Nov 29, 2013 | 11:36 AM
wyoming9's Avatar
Red face
Does the washer have a special notch to hold them in place??
Why can`t you use just a bolt with a fender washer?/
This part of the country they get cut out.
Good luck
Old Dec 1, 2013 | 11:04 PM
buickid's Avatar
Yes, I believe the washer is part of the head, keeps it from rotating so you can just tighten the nut from the bottom. Not too sure of that, but it seems logical. If I can't find the Toyota part, I'll have to grab some hardware from a local nut and bolt shop.
Thanks!
-Trevor
Old Dec 2, 2013 | 03:42 PM
buickid's Avatar
Found, thanks YotaTech!
Jun 1, 2021 01:51 PM
mskalmus
May 28, 2017 07:51 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
