Weird popping noise when going up and down hill and around curves from the front end.
Old Jan 11, 2021 | 12:14 AM
Mytoytssitthebed's Avatar
Hey there, so I’ve been in a bit of a haste the past two months with my 4Runner, it’s a 2003 4.7 4wd sport edition, so I started to get this popping noise coming from the front/middle of the vehicle. Now keep in mind before this happened my transfer case would never let me go into 4low so I never touched it. Anyways, the popping noise continued to get worse and worse so I figured it’s An axle so I replaced the axles, meanwhile it still done it. So I took out the center differential and turned on differential lock and it would go just fine without a popping noise so I figure it was the front driveshaft so I replaced it with a brand new one. Same issue, soon as this started happening my transfer case started to work and I could drive in 4low, before the transfer case would never lock into 4low. Ever. It will not pop when the road is complete straight, but if there is a hill or a bump or a curve it pops, like so badly you can feel it through the whole vehicle and hear it outside the vehicle, one thing I tested with the new front driveshaft was that I put the truck in 4low and it was literally able to go up to 50mph.... like wtf?
im running in circles here lost and I have no idea what to do, I have a family of two and I’m just so lost cause it’s the only vehicle that we have.
what is your thoughts
Old Jan 11, 2021 | 05:38 AM
Bump bump bump
Old May 26, 2021 | 05:29 PM
STC's Avatar
STC
Is is a single pop? or does it cycle over and over? If so, is it speed dependent?
Is there any association with wet conditions?
Ry.con
Feb 22, 2016 02:50 PM
Mojave_Moze
May 19, 2011 02:17 PM
xenogear_id
May 15, 2009 03:38 PM
mini_fly
7
Feb 5, 2009 04:29 PM
Tiger Paw
Jan 23, 2006 01:42 PM
