Trailer Brakes
Old Sep 28, 2006 | 06:25 PM
AH64ID's Avatar
Trailer Brakes
The trailer my wife just bought has brakes on it. It only weighs 950lbs, but I figure what the heck it has em, I'll use em. The 4Runner already has the 7pin connecter, so does it have a plug and play device under the dash for the brake controler?
And where are you guys putting your brake controlers
Old Sep 29, 2006 | 05:52 AM
Koz's Avatar
Koz
Get the Prodigy controller and the Toyota direct wiring harness (from Prodigy). There is a factory plug under the dash on the driver's side. It comes up from behind the side kick panel. You can mount the controller on the fuse box cover. You can get a replacement cover from the stealer for when the controller is not in use.
Koz
Old Sep 29, 2006 | 06:06 AM
AH64ID's Avatar
thanks for the input.
Old Sep 29, 2006 | 02:28 PM
metalhed's Avatar
Cool Koz, does the same plug and play exist for the 01 taco?
I am looking at the same issue, new trailer with brakes. Why not use em
Old Sep 30, 2006 | 05:09 AM
DiskDoctr's Avatar
Koz is right. I did the exact same thing. I'll take a pic of the mounting.
The 4Runner and Tacoma use the same plug. When I got mine, the 4Runner plug wasn't available yet, used the Tacoma plug.
If you have the tow package, there should be a pigtail in the glove box that shows what the end looks like under the dash, to the left of the steering wheel. Don't use it, since for about $10, you get one from Prodigy with both ends you just plug in.
See my post in this thread for more info on the Prodigy controller.
https://www.yotatech.com/forums/f117/tow-capacity-2004-v8-2wheel-drive-tow-package-89914/
I'll go take a pic and post it shortly.
I regularly tow up to the max (7k) with my '04 Ltd 4Runner. Not an expert, but lots of experience, I'll share what I know, just ask!
-DiskDoctr
Old Sep 30, 2006 | 05:33 AM
AH64ID's Avatar
Thanks. Appreciate all the info...
Old Sep 30, 2006 | 05:35 AM
DiskDoctr's Avatar
Prodigy mounting and pics...
Overview...
Mounting clips pulled (removable unit), but wires still attached
Mount with Prodigy removed
-DiskDoctr
Old Sep 30, 2006 | 05:37 AM
DiskDoctr's Avatar
One more. Shows the wiring. See the Prodigy mount wires in the bottom right corner and the top right shows the white connector under the dash.
I had to cut the zip tie when connecting it, then put a new one on.
Not the best pic, but it's hard to get lighting in the rain
Hope this helps.
-DiskDoctr
Old Sep 30, 2006 | 05:45 AM
AH64ID's Avatar
Sweet, really appreciate it. I read thru the other thread too. I think thats the controler my dad has in his cummins and really likes it.
sidenote.. whats that switch all the way to the right? VSC off??? I could like one of those..
Old Sep 30, 2006 | 05:56 AM
DiskDoctr's Avatar
That switch on the right? Oh, that's the chaff deployment switch. Can never be too careful these days...
Just kidding. It is the RSCA off, side curtain airbags, so they don't deploy if you are offroading a little rough. Even if off, they're supposed to deploy on impact, like a complete roll, but won't anticipate in a steep tilt.
I haven't tested that theory, just what the dealer told me.
If you want to see all the gauges and buttons light up at once, just get it going and off the ground for about 3 seconds (around 65-70mph over a good hill) and the whole thing lights up and beeps. Lots of fun...
-DiskDoctr
PS- forgot to mention, secure all loose change and drinks first. You've seen videos of Nasa's upchuck zero gravity plane?
Old Sep 30, 2006 | 06:03 AM
AH64ID's Avatar
Yeah, I have had all the beeps and whistles go off on the gound... playing on the snow.. if was funny me and my buddies went up in the mountains to go to some hotspring, the road had about 1' comact snow on it so I was utilizing the AWD and trac control... it would flash if I slid, then beep if I slid a lot.. my buddy say "your rig is telling you to knock it off or its gonna tell the wife how you drive!"
:pat:
sniper34639
Aug 31, 2015 07:56 AM
Scatterbrain
14
Aug 31, 2015 06:26 AM
dropzone
Aug 11, 2015 05:16 PM
58rennur4
Aug 4, 2015 08:49 AM
shadowbirdie
Jul 21, 2015 10:38 PM
