Steve's lift kit installed!
Reference data:
265/65-R17 Dunlop AT20 - 30.6" tire, 96" circumference;
265/70-R17 GoodYear MTR - 31.9" tire, 100" circumference; -4.2% on speedometer;
275/70-R17 GoodYear MTR - 32.4" tire, 102" circumference; -6.3% on speedometer;
285/70-R17 GoodYear MTR - 33.0" tire, 104" circumference; -8.3% on speedometer.
265/65 is ~8.3% less in diameter (stock Dunlop compare to 285 MTR), so I wouldn't recommend to use id as a spare with 285/70. Too much trouble. 275/70 (the maximum you can fit under the truck) and 285/70 have ~2.0% difference in diameter.
Reference data:
Reference data:
I want 285 for a bit extra height. I know it not that much but an extra inch can increase my manhood confident.
#25
Yes, you can. Just remember to inflate your spare ~5psi more then other and when you use it deflate the opposite tire ~5-10psi. In this case you'll have 10-15 psi difference and this should bring the difference in diameters to the minimum. And also, do not drive too fast on this setup. This should get you out of the trail to the tire shop, where you bets bet is to repair 285 and put it back; don't forget to bring the deflated tire back to normal.
#26
#27
Depend on type of the tire you may have rubbing issues or not.
AT 285/70-R17 will rub just to triangles under the bumper.
MT 285/70-R17 will require trimming of the inner fender.
My friend has 285/70-R17 BFG AT and he had only heated and bends those triangles.
I had 275/70-R17 GY MT/R and they rubbed to the inner fender a little bit. So 285/70 will rub much more.
#28
#29
#30
#31
#32
2006 4Runner Lift Kit
I just got a 2006 4Runner Sport. Want to lift exactly like these pics...but I'm curious how high the truck actually is. Having a hardtime picturing it. Can somebody post a picture with them standing next to their truck with a 2" rear and 3" front. Also, I like the look of the black 4runner at the beginning of this thread...do those wheels have spacers on them to push the tires out alittle? I like that look rather than the tire/wheels being in from the body alittle.
Thanks! (New to this whole thing)
- Jay
- Jay
#35
How is the Cornfed holding up on the XREAS's?
I'm considering a Cornfed 3"/2" install on an '08 Sport Edition 4WD V8 XREAS. Was wondering how these installs are holding up over the years? Did you keep the XREAS and if yes how is it holding up? How has the ride been? Any CV or Dif or alignment problems?
PS the cornfed lifts look sweet.
#37
im sorry for this question because i am just so new to this. i just got my first '05 4runner as my first car and i wanted to know jason, if i got that 3",2" lift what is the max size tire that would really work? can you tell me in inches because i dont understand what the 265/65 stuff means. like if i could put some km2's in there?
thanks for helpin a true beginner :]
#38
http://www.burtmanindustries.com/zoo..._03_up_liftkit
#40
From Steve:
Hey the truck is doing great and i get compliments
everywhere!!! Im running 285/70/17 on american eagle 187s. THe offset is
4.65mm. Even with the aggressive offset i still had to do some trimming on
the fender well. I also had to remove the front mudflaps. The acceleration
diff was minimal and the truck rides great. No real tire noise or vibration,
even at 100mph+! Well if you have any other questions feel free to email me.
Also, the lift kit is going up $10 starting July 1st. No control over this due to material costs. If you order before then, you save. : )
Lift kit write-up/more pics
Thanks!
