Multiple codes, VSC/Trac/Check engine lights
Old Sep 15, 2011 | 05:40 PM
mrt555's Avatar
Hi All,
I am new to the forum and have a 2005 Sport V8. I have had my VSC, TRAC, and check engine light on for about a month, and 4 days ago my truck went into "limp home mode" and I have no power. The truck is very sluggish, can barely make it up a hill, won't go over 4k rpm in park, and only makes it to about 25-30mph slowly. The codes it threw are:
P2440 - Secondary air injection system valve stuck open (Bank 1)
P1441 - No info
P1444 - No info
C1201 - Engine control system malfunction
Also, I took it in a couple of days before and the codes at that time were something about Catalytic efficiency below threshold. He cleared the codes before I got any numbers or more info. I think it may have been both banks. It is also more throaty sounding. Similar to when I installed a CAI on my Xterra, but this is just a little louder, and I don't like this one...
I really don't have the $1500 I was quoted to have the injector valve replaced. How hard of a job is it? My guess is that my valve is bad, and i may have a combination of bad O2 sensors and cats. The truck has 160k miles. I need to try to do this as cheap as possible. I was thinking of changing both O2 sensors first. Not sure if I would need to change the A/F sensors. If that doesn't work, then change atleast one of the cat's. After that, the other cat. Finally if all else fails, the Air injection valve which I can't find a price for online. What do yall think. I'm just taking guesses. Or maybe 1 cat and O2 sensor together. then other side. Any help would be appreciated! have been using 10% ethanol gas, and I put Seafoam in the day before this problem got really bad. I did find out that the battery was going bad, and replaced it. Truck ran great for a minute or 2, then lights came back on and went back into limp home mode.
Thanks,
- Mike
Charecter1
Nov 6, 2023 10:08 AM
Jun 1, 2021 01:51 PM
steve miller
Oct 10, 2015 01:40 AM
Jnkml
Jul 6, 2015 01:20 PM
coryc85
Jul 6, 2015 04:07 AM
