MPG Drop & smell after 02 Sensor Change..
Hello,
I've got a stock 03 4Runner v6 4WD. After a trip to yosemite last year in the winter my front 02 (california spec) sensor went out. The dealer changed it out for me. Ever since then I can smell the fumes coming out the exhaust and my MPG has dropped by 6-8 MPG. I bought a OBD II reader and everything seems in line ? I changed out the spark plugs and the air filter and the same thing?
Any advice ?
Thanks
Rany
Any advice ?
Thanks
Rany
Have it checked at the dealer.
Catalytic converters are usually covered as part of the emissions system which follows a longer warranty period, 7/70 usually.
The fact that they 02 sensor was replaced because it was giving bad readings leads me to believe you have a bad cat. Was it the pre-02 or post-02. Usually there is an 02 sensor before and after the cat.
Seems like the emissions warranty is something like 8 years 84,000 miles. I'm not totally sure of the exact years/miles, but I do know that it's the same coverage period for every vehicle and that it's federally mandated. As a matter of fact, I think that the O2 sensors are covered under the emissions warranty, so you shouldn't have had to pay for it the first time.
I would check into it.
Blamalam
Mar 12, 2022 07:34 AM
sandyota
Feb 4, 2021 11:16 AM
