Misfire Issue
Old Oct 13, 2019 | 12:45 PM
RedT4R's Avatar
Misfire Issue
I have a 2006 4.0 Sport, during my last drive on the highway the truck started running rough, the CEL started blinking and the traction lights came on - pulled the codes found p0300, p0301, p0303. Swapped coils to see if the misfire moved, nope still the same. I noticed heavy fuel smell and fuel leaking out of the tailpipe - so I pulled the plugs to check them. They all need to be changed due to age but cylinder one and three spark plugs were black(rich) and I looked into the cylinder and could see fuel in the cylinder - I also checked compression in all three of the cylinders and it was all
around 180psi soI am thinking it is a injector issue but wouldn’t I have a code for the injector?
Also notice gas went from 1/4 to 1/8 just idling. So it’s definitely dumping fuel
Any help would be greatly appreciated thanks!
Old Oct 16, 2019 | 03:05 PM
old87yota's Avatar
If the injector circuit passes the test from the ECU electrically, they will not throw codes.
With "modern" vehicles, it is best to have a scan tool capable of displaying live data so you can monitor to see if anything looks out of place while the engine is running.
As I am not that familiar with 2006 4Runners, I cannot really give any common things to check for.
2001tacoma_trent
Apr 26, 2021 10:46 AM
Hyperlite
7
Jun 15, 2012 05:43 AM
HawkGT
12
Jan 26, 2009 07:14 PM
Jcod12
Feb 21, 2008 02:29 PM
