How to disable ABS on '07 Tacoma off-road prerunner
New guy here-- I need to disable the ABS on our purpose built mostly off-road Tacoma now that it will see duty as a Baja support vehicle. Other than pulling a fuse or the harness off the abs pump is there a more elegant solution such as substituting a switched resistor to "fool" the ECU? Anyone BTDT? TIA.
DO you have a locker? That will do it. If not, there's got to be a hack somewhere. If engaging your E-locker disables ABS it's got to be done electronically. I bet you could find out how to do that on this forum.
I was thinking about installing a relay after with the ABS fuse and running a switch into the cab. I know a couple other people have talked about it, but I have not looked into it recently. Good luck.
nvwiggins
13
Jun 16, 2016 03:05 PM
FS[FourCorners]: First Gen Tacoma/4Runner Manual Hub Spindles
G-off
Dec 29, 2015 12:44 PM
zz_denis
Sep 6, 2015 03:43 PM
