Help Diagnosis Engine Nose Help
Old Nov 10, 2012 | 11:14 AM
badbob94's Avatar
Last summer went wheeln with my kid in my 04 v6 T4R. We went through a few axle deep water crossings. Some at around 15mph.
When we got back on the paved road the engine sounded different. There is an "AAAWWWWWGGGGGG" sound in the background of the normal engine running. Opening the hood it sounds like its in the lower end, perhaps in the AC pump. Turning on the pump doesn't change it. Cranking the steering wheel doesn't enhance it so I don't think it is the PS pump.
I changed the oil, check all fluids, check the air filter all is well. No codes or lights either.
Any ideas what it could be? Should I try and track it down or just wait until something breaks?
Thanks,
Badbob
Old Nov 10, 2012 | 11:58 AM
ksti's Avatar
Check idler pulley below PS pump.
Old Nov 10, 2012 | 01:47 PM
badbob94's Avatar
I suppose I need to take the belt off and inspect the idler. Or is there an easy test like squire some WD40 in it and see if the noise stops?
Thx,
Badbob
Old Nov 10, 2012 | 04:55 PM
ksti's Avatar
Thx,
Badbob
You could, but it's sealed and I just don't think it will help, so just pull the belt and you will know positively. Good Luck
icentropy
Sep 16, 2020 02:47 PM
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
rushw
Jul 18, 2015 01:46 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
razorman8669
Jul 12, 2015 12:13 PM
