Old Mar 30, 2016, 10:51 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tacoma Lighting Guides
Print Wikipost
Fog Light Mod - on when you WANT them to be on, not just with the low beam headlights
Old Aug 10, 2011 | 06:29 PM
iamsuperbleeder's Avatar
Originally Posted by poynter
I need to do this.
'tis super simple
Old Mar 10, 2012 | 08:07 AM
Muverick's Avatar
My experience with this mod:
I performed this mod on my 2006 SR5 4Runner, and found the following:
1: the relay info is good, but the tab was the other one.
2. the 'constant power' wiring option allows all BUT THE HIGH BEAM option; the fog lights STILL go out when the high beams are on.
3. the 'fog light' indicator in the dash lights,even when the ignition is off, so there is a reminder. {:->
In short, this isn't perfect, but it works for me. Thanks, Travis.
Old Mar 24, 2012 | 03:49 PM
that's kind of odd...
what "other tab" are you talking about? if it's the same relay, the pins are the same, so hooking it to another tab just wouldn't work at all
almost 10 months later, and this is still working great for me BTW; no issues what so ever!
Old Mar 25, 2012 | 05:13 AM
Muverick's Avatar
I'll have to take some pictures to prove this, but I did as the photos showed, and the fog lights stayed on all the time. Consequently, I used the other tab of the tabs shown as parallel to the sides of the relay. Subsequent investigation indicates the issue with the high beams turning the fog lights off is possibly a mechanical change initiated by the turn signal/headlight/high beam stalk itself, that turns the fog lights off when the high beam aspect is engaged- even when the vehicle is off (no key in ignition and no other lights are on). Remember, this is a 4Runner, NOT a Tacoma. It is what it is.
Old Mar 30, 2012 | 08:20 PM
  #25
huh, they must just use a different means of switching the power on the 4Runners
I'm not saying I don't believe you, it's just odd that they'd make them operate so differently, lol
Old Apr 18, 2012 | 09:27 AM
  #26
Jacob Cramsey's Avatar
must do on my '12 Tacoma
Old Apr 19, 2012 | 03:57 PM
  #27
I tried this mod on my '12 and needless to say its a bit different in the fuse box area. Managed to get it figured out. They have a separate box for fog lamp and a few other items. ran the power wire right to the battery
new wire going to relay
wire running through the side of the second relay box
better idea of where second box is at
job all complete
on when i want them on
Old Apr 21, 2012 | 09:06 PM
  #28
cool!
nothing like hacking into a brand new vehicle
Old Apr 22, 2012 | 02:28 PM
  #29
speaking of hacking into a new vehicle i had to relocate my trailer hookup do to smashing it the first time i took the truck offroading. I simply removed one tag light and put the trailer hookup in its place.
Old May 17, 2013 | 12:56 PM
  #30
DennySmith45's Avatar
Wow. Best descriptive fog mod on the net. Speaking of which: does anyone know if replacing stock halogen fog lights with LED's will screw up the CAN-BUS and get bulb-out warning messages? (2008 Taco)
Old May 17, 2013 | 03:07 PM
  #31
I think you can order can-bus specific LED's, can't you? I know you can do something about it when going to HID's; didn't have to with my 06 but I've heard of others having to do it on newer trucks, at least with headlights anyways, not sure about fog lights
Old May 17, 2013 | 03:38 PM
  #32
Thx. Went HID and luv 'em. Figured LED's on fogs, but lottsa' talk about CanBus. I'll go with 'em. Not out too much $$ if they screw up. Thx for all of your help.
Old May 19, 2013 | 12:25 PM
  #33
For the none-too-swift like me: remember when testing the mod to set the fog light switch to "on" position. Otherwise, you'll be disappointed.
Old May 31, 2013 | 05:02 PM
  #34
flyAddict's Avatar
What's hilarious is that I forgot I had done this mod about 4 years ago. My driving lights aren't working now but both bulbs are good. Was working on troubleshooting it and came accross this mod article. Though, Hmm mine just worked that way, then started reading and thought... Wait this looks familiar. Sure enough I've done this mod only tapped into a live ACC wire behind the DS headlight. Perhaps that's my issue. No fuses are blown, probably just a bad connection. However I've tested the big ones leading up to the lights and they're fine. More testing to do...
Old May 31, 2013 | 05:30 PM
  #35
flyAddict's Avatar
Anyone Have a OEM Wiring diagram for 2005 4th gen 4runner. I have most of the manual, just not a front lighting wiring diagram. It's definitely shorting somewhere forward of the hood fuse box relay. Neither lead to the actual fog/driving lights is live. Lights are fine.
This means it's shorting out after the hood fuse box and modified relay and before the driving lights on my ARB bull bar. (installed several years ago and the base connections to the lights have started to corrode. I've cleaned that up and dielectric greased it on both sides) but now it seems there is no power getting to them from the OEM source.
Side note: Does anyone know of a brand that makes a touch sensor for <12V DC current, mine all do AC. A touch DC sensor would be huge in troubleshooting this issue.
Old Mar 18, 2014 | 02:20 PM
  #36
DaGimp's Avatar
I registered just to say thanks for the Write up.
I just finished installing this mod, the Relay was in a slightly different place on my year but it all still worked.
Old Jan 16, 2015 | 07:06 PM
  #37
06yota's Avatar
Great write up
Loved the write up! But wondering where you got the female quick connect that you attached onto the bent prong of the relay?
Old Oct 28, 2017 | 07:10 AM
  #38
stephendtundra's Avatar
Smile 00 Tundra - almost works
Thank you for the very clear illustrations! I followed your guide with the first option, wiring directly to the power source in the fuse box, and now my fog lights work whenever, EXCEPT when I have my low beams on. Would you happen to know the reason for this? Any input would be appreciated!
Thanks again for the thread!
2000 Toyota Tundra, Reg. cab, V6 Manual
Stephen
Sleaker
Aug 26, 2020 06:03 AM
fountain
Dec 31, 2015 06:08 AM
Sep 4, 2015 09:27 AM
rushw
Jul 18, 2015 01:46 PM
Massmayhem247
Jul 18, 2015 05:46 AM
