Electronic compass/outside temp display
Old Jun 11, 2011 | 03:14 PM
William's Avatar
A little while ago, I was riding around exploring the northern New Mexico desert. I looked up and noticed my compass/outside air temp display had quit working. The display was totally dark. I had been bouncing around some, but not all that much, and no worse than usual.
Everything else is working, and since something like that would most likely share a fuse with something else, I don't think it's a blown fuse.
Has anyone experienced this? What should I check? Is there a common problem with the display that I can look for? I've never had it apart.
Old Jul 19, 2011 | 05:06 AM
Trip3110's Avatar
BUMP!!! I just bought an 06 tacoma and my compass display also does not iluminate.
SUGGESTIONS???
Old Dec 30, 2011 | 11:54 AM
William's Avatar
I didn't realize you had posted because I hadn't updated my email address.
So has anyone experienced this?
Old Dec 30, 2011 | 04:57 PM
iamsuperbleeder's Avatar
I hear they're common to go out, but I honestly have no clue as to what goes out on them
it may be easily repairable if you've got a steady hand with a soldering iron
Google search might reveal a little detail on the issue
Old Dec 31, 2011 | 05:34 AM
William's Avatar
It's been a while, but I never found anything on them that gave any useful information. And it looks like it's a pain to remove. Maybe soon I'll find the time to give it more effort to take it apart.
Old Dec 31, 2011 | 06:38 PM
blisters13's Avatar
Sure would like something better than the crappy LCD (why Toyota used this low-tech and hard-to-read assembly is beyond me)....
Old Jun 26, 2013 | 05:04 PM
William's Avatar
It's been over 2 years, and the display is still out. Yes, I know I'm lazy, lol. So no one has any ideas?
Old Jun 26, 2013 | 06:51 PM
I repaired a non functioning one a few months back and installed it in my 06 it's been working great every since!
http://www.tacomaworld.com/forum/2nd...-temp-fix.html
this is what mine looked like when I got in there:
Old Jun 26, 2013 | 07:12 PM
William's Avatar
Thanks for the response. I just might finally get around to fixing it this weekend.
Old Jun 27, 2013 | 05:41 PM
it's not hard at all maybe a 10 minute job, providing you have a soldering iron (an IRON (pen type) like 30-50 watts, don't use a GUN type with the trigger; you'll burn the resistor up, they get too hot)
it's also worth noting, if you get in there and the problem isn't as obvious (like a resistor about to fall off like my photo above), heat up and reflow the solder on those 510 resistors anyway. they could just have stress cracks in the solder and the joint could be week or incomplete
also, I added a little new fresh solder to mine when I did it
keep us posted
justdifferentials
14
Jun 11, 2017 08:36 PM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
bradahman
Oct 1, 2015 09:24 AM
Matthew Perez
Sep 28, 2015 05:43 PM
rmill05
Sep 27, 2015 01:43 PM
