Daystar 2 1/2 leveling kit install with pics
Old Apr 8, 2008 | 09:06 PM
shancerlelby's Avatar
This week we had 2 06 tacos in at work today so i figured i'd throw up a thread on how to install the spacers since there seem to be alot of these trucks running around with a serious rake problem (low in the front high in the back) An old 60's muscle car comes to mine and well personally i dont think that suits these great trucks. So here is the thread.
The kit part number is kt09116 for the 03 - 06 toyota 4 runner / 05 - up toyota tacoma 6 lug 2wd and 4wd.
the gear.
the truck.
step one, put on your snap on gloves pre shot 4 3/4 inch fender gap.
-jack vehicle and place securly on jack stands
-Remove wheels
-the sway bar end links and remove the upper ball joint cotter pin and nut.
-separate the upper ball joint from the spindle using the appropriate ball joint -separater pickle fork. (or with a large hammer hit the steering stop afew times till it dislodges. careful they spring apart hard sometimes heh.
-remove the three strut tower nuts and remove the lower strut mount bolt and remove the strut from the vehicle. (watch the tension on the brake line and abs wires) i had an asistant push down on the lower arm while i used a pry bar to duslodge the lower part of the strut.
- using a coil spring compress compress the spring and remove strut.
- press in new studs onto top strut mount
- install spacer between coil and upper strut mount and reinstall coil etc. 18 ft lbs for top nut.
- install tapered spacer onto top of strut
using an asistant again reinstall the strut assembly
- install lower strut mount bolt (100 ft lbs)
- using a floor jack raise the lower control arm and connect the upper ball joint on the control arm to the spindle torque nut to 40 ft lbs and replace cotter pin.
- reconnect the sway bar end links and remount to chassis.
- install wheels and lower vehicle onto ground and tighten up upper strut tower nuts to 35 ft lbs
- take off your snap on gloves.
space between upper A arm and tyre. 3/4 inch
new measurement
and theres your truck
rally as necessary or if your me consider owning your own tacoma and not just working on them to get paid.
jerusry
Oct 19, 2015 05:28 PM
Sep 4, 2015 09:27 AM
Jonny246
Jul 12, 2015 04:51 AM
crashburnoveride
Jul 10, 2015 06:39 AM
Yotoder865
Jul 9, 2015 07:51 PM
