Clunk in rear suspension?
Old Feb 28, 2006 | 06:27 AM
Lookin''s Avatar
Hi All,
Somewhat frequently I get a clunk from the rear of my 04 4R. It happens after I come to a somewhat fast stop and when I release the brakes to go again. It feels like someone just bumped me from behind. Has anyone else had this problem?
Dave
Old Feb 28, 2006 | 12:25 PM
Good Times's Avatar
You're expeciting axle wrap/wind-up. It happens when the rear driveshaft skip joint binds up. If you stop abruptly, the rear axle will rotate down a little and the driveshaft slip joint will open up slightly and then stick in place. When you release the brake and accelerate, the shift in vehicle position will cause the slip joint to "jump" back in place giving you the "thud" feel/sound.
If you lube the slip joints 99% of the time, the problem will get resolved. Some other alternatives is to take it into Toyota but all they'll do is lube and call it a day.
Btw this has been covered as it's a very common issue for many of us. Search for some of the key words and you'll definitely find a lot of details on this issue.
Good luck
Old Mar 1, 2006 | 05:43 AM
Lookin''s Avatar
Thanks Good Times--- Since I posted I did find what you have told me. I never did find a definitive answer on the grade of grease to use though. Does it matter?
Old Mar 7, 2006 | 06:24 AM
Lookin''s Avatar
Thanks to all.... a little grease and all is well! What a simple fix for something I thought was going to be a battle with the stealer. Thanks...
Old Mar 19, 2006 | 05:14 PM
98runn'n's Avatar
I was experiencing the same problem in my 98 when I first bought it 2 months ago. I was told from some Yotatech faithfuls that I needed to lube the driveline and U-joints and the problem was fixed thereafter. I too was expecting the worst, but thank God it was as easy as shooting some grease in the Runner. I believe if you do a search on this site you can find a pretty detailed write up on where to lube and what lube to buy. Good luck.
Old Mar 19, 2006 | 05:26 PM
Bob_98SR5's Avatar
it is in the maintenance subform in the tech section. and as far as what grease to use, look in the back of your manual in the "specifications" section.
noobs, take some time and look around in the tech section. there are some really good writeups in there. note that searching *may not* always pull up a writeup, depending on the key words you use. thus, look in the tech section
bob
Jun 1, 2021 01:51 PM
Yotadawgjr
10
Aug 23, 2015 10:51 AM
coffey50
Jul 28, 2015 10:55 AM
andrewtexas123
Jul 23, 2015 11:22 AM
Vargntucson
Jul 4, 2015 12:15 PM
