Center Differential Lock - Mind of Its Own
I have an 03 4Runner with 54,000 miles.
Today, when I started the car, the center differential had locked as evidenced by the center differential LED being lit. I had done nothing to make that happen. Prior to starting the car, it had not been driven on anything other than smooth roads.
I tried to get the differential unlocked by depressing the center differential button. However, all I would get was a flashing center differentiallight. Also the VSC LED was on.
I then drove the car a couple of miles with the center differential LED light on. Then I parked, turned the car off and depressed the center differential locking button a couple of times. Nothing worked. Still getting a flashing LED center differenial light.
Then I started to drive and after going about 10 feet, I heard a distinctive clunk, which I assume was the center differential unlocking. The light went off and now everything seems normal.
Does the car need service? Did I do any damage with the center differential locked? Any explanation for why this happened.
Thanks
John
Thanks
John
dumb question here
when is the last time you had the diff fluids changed or checked?
I would check the fluid levels and then check the electrical connections
when was the last time you used the locking diff?
Shantz
Don't really appreciate being called dumb. I have raced a 911 for the last 10 years and do most of the work myself. My racecar does not have this kind of differential and I am out of my element with automatic transmissions.
So tell me, mr. intelligent, why low fluid would automatically lock a differential. I don't think it seized.
As for the last time I used it, the answer is never.
The manual says you're suppose to switch to the different modes periodically to keep the solenoids "lubricate". I forget the specific numbers, but it's like 10 miles a month in 4WD (if you have a V6, but seems you have a V8 from your post), every 6 months in 4LO etc. That may explain why yours took longer to switch to unlocked if you never use it, but I don't know why it would have been in that mode already. The button really isn't in a place that you would "accidentally" push it either.
When it was flashing, where you driving in a straight line or constantly making turns? I've noticed the 4Runner likes to be in a straight line when changing modes or it it takes longer to switch.
You're not suppose to have the center differential locked on smooth pavement, but if it was only a few miles without a lot of turns you should be ok.
Thanks
John
Thanks
John
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
justdifferentials
Just Differentials
Aug 30, 2015 08:42 PM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
WTB[PacSoWest]: Looking for a electric locking differential motor/ actuator
AaronM
Jul 8, 2015 07:15 PM
