center console bulb replacement?
Old Jan 17, 2007 | 07:45 AM
DIHOWARD's Avatar
anyone done a bulb replacement in the center console "03 4Runner??
It's the "TEMP" paddle switch in center control, left side. the dealer wants $151.00 to replace it, ouch!
Old Jan 17, 2007 | 08:34 AM
Good Times's Avatar
I know you can pop the panel off for the a/c control but have no clue how to replace the bulb inside there. You can pop the panel and take a look from behind to see if it's even possible.
1. open bottom compartment (that small pocket under the a/c controls).
2. Pop off compartment (gentle nudge should do it)
3. look at the latch for the opening and you will find a phillips screw inserted.
4. Unscrew (1 bolt)
5. Gently pull the bottom of the a/c panel.
6. disconnect cable (should be 1 if not 2 but I'm sure it was 1 only)
7. look at the backside to see if you can even remove the switching mechanism to get it the bulb replaced.
if all else fails hit the junk yard first cuz it'll be cheaper. if not check out these fine vendors:
https://www.yotatech.com/forums/showthread.php?t=72371
http://www.trdparts4u.com/
https://www.yotatech.com/forums/showthread.php?t=102643
good luck
msane99
Jul 11, 2015 08:08 PM
hangtown88toy
Jul 10, 2015 02:33 PM
akaphilly
Jul 9, 2015 02:34 PM
madxman21
Jul 9, 2015 10:26 AM
ptb12
Jul 5, 2015 01:49 PM
