2003 rear defrost & rear wiper
Old Dec 27, 2006 | 06:58 AM
micg1313's Avatar
Anyone have a solution, to this problem. My rear window defrost will not work,along with the rear window wiper. I checked fuses and there good. I dont now if 30amp relay is bad . Any help would be awesome.
Old Dec 27, 2006 | 10:05 PM
TechWrench's Avatar
Most likely one of two things. Either you don't have the rear window fully up or you recently disconnected the battery, and the controller needs to be reset. Try lowering then raising the window once first. If it wasn't fully raised, that should fix it. If you have disconnected the battery recently, they I believe you will have to fully lower and raise the window several times to 'reprogram' it. If that was the problem, you may also have to cycle the sunroof open and closed several time also (if you have one).
Old Dec 30, 2006 | 08:57 AM
micg1313's Avatar
Tech.
Just Want To Say A Big Thank You ... I Was Ready To Make Appointment With Dealer. Thanks Again..
Mic.
Old Mar 19, 2007 | 03:12 PM
kaneman23's Avatar
A big Thank You from me as well. I had the exact same issue occur yesterday after disconnecting the battery. I disconnected the battery with the truck running to test my altenator. Funny that the truck kept all other configurations except that one..
Old Feb 8, 2010 | 03:09 PM
Count__Olaf's Avatar
Thanks from me also. I was banging my head on trying to figure this out.
MO transplant
Apr 23, 2023 11:58 AM
ghostmoney
Jan 28, 2018 11:42 AM
mskalmus
May 28, 2017 07:51 AM
msane99
Jul 17, 2015 10:13 AM
icentropy
Jul 14, 2015 10:23 AM
