'03 4runner going to dealer. advice?
Old May 22, 2008 | 08:09 PM
jayhackett03's Avatar
i just bought my '03 about 5 weeks ago, i'm taking it in to Olathe Toyota tomorrow for:
1) exaust leak on driver side manifold, 1st cylinder.
2) driver side windshield trim ripped off at 75mph.
3) sunroof leak, leading edge.
i'm just seeing if any of these things are common and if you guys had any further info on them.
Old May 22, 2008 | 08:46 PM
86tuning's Avatar
sunroof leak could simply be plugged up drain hoses, which are coincidentally located in the front edge of the windshield tray. Test by pouring 1/2 cup of water in the tray to see if it flows down the little drains at the front corners above the a-pillars.
If one side is plugged by debris, clear it out by GENTLY blowing some compressed air through them.
Water should drain down the a-pillar drains to the front fenders somewhere.
HTH.
Old May 23, 2008 | 05:17 AM
JGage's Avatar
I've got over 100k on my 2003, not one single problem to date.
Old May 25, 2008 | 06:49 AM
for the exaust leak they said that both manifolds were rusted out and needed to be replaced.....$2873.06!!!!!!
the windsheild trim i'll hafta buy by myself and take to a windshield shop.
Old May 25, 2008 | 10:25 AM
dirtoyboy's Avatar
That sounds steep..I would take it to a "competent" exhaust shop and get some quotes or advice. Hard to say without pics of the damage.
Old May 25, 2008 | 10:29 AM
DeathCougar's Avatar
The reason they charge so much is the cats are welded into the manifold, IIRC.
If not...its still a ton of labor to remove those manifolds off those things, especially given the rust problem.
Old May 25, 2008 | 10:55 AM
1stgen4gunner's Avatar
do you know any good local mechanics, dealers usually have good mechanics, but they are very expensive so be prepared for a hefty bill.
snosurfer
3.4 Swaps
Aug 15, 2024 02:11 AM
icentropy
Sep 16, 2020 02:47 PM
nanhodges2733
May 29, 2020 03:28 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
skoti89
Jul 8, 2015 12:05 AM
