Yota on fire.
Old Dec 10, 2009 | 07:49 PM
camo31_10.50's Avatar
could be??? all the wires are connected EVENTUALLY..lol at least to a certain extent
Old Dec 10, 2009 | 07:56 PM
toyotabull's Avatar
I would atleast unbolt the fuse box and make sure you dont have a wire touching the wall, if not start pulling relays and trace it back. Or pull all of your fuses and put them in one at a time and see what happens. Good luck to you
Old Dec 11, 2009 | 07:44 AM
Matt16's Avatar
Originally Posted by Blk63vette
Hello
I seen car burn up fast (Esp. Corvettes). Dude your life is not WORTH risking over being in a car that catches on fire.
My buddy got burned bad trying to save his vintage Corvette. I carry a fire extinguisher in my Corvette always.
Presumably, he'd have the good sense to get out of the truck once it started burning. Don't think an electrical fire is life-threatening... unless you're carrying a black powder crammed into the glove box, which I suppose he might given the pic of the deer that-don't-know-what's-coming in his avatar.
Old Dec 11, 2009 | 08:15 AM
Green_slime's Avatar
if your lights stay on when the fuse is pulled out is a sign of wires touching somwhere because on any normal truck if you pull the fuse it would go off because it would have no power to it
Old Dec 11, 2009 | 08:33 AM
  #25
OrRunner's Avatar
Originally Posted by PickupMan
I have no choice. No other vehicles. I just carry a 10mm with me and hop out quick and disconnect the battery once i start to see smoke.
I this for real? if your going to keep driving this truck your just going to cause more damage and spend more money fixing it. park it, trace it, fix it, then drive it. best advice i got....good luck!
Old Dec 11, 2009 | 08:36 AM
  #26
cgeorge's Avatar
I wouldn't drive it... but others have already made that point clear.
I think you'll toast a lot more than a few wires if you continue. I would think finding the short would be easy by now since it has been causing a stink several times. Electrical shorts, in my experience, have a unique smell once they've burned a certain # of times.
Old Dec 11, 2009 | 03:16 PM
  #27
bone collector's Avatar
STOP DRIVING THE TRUCK!!!!
Old Dec 12, 2009 | 01:36 AM
  #28
milehigheric's Avatar
Honestly If you have had actual flames there is a good chance your whole loom could be trash, depending of course where the short is and what circuits are involved. By the time a flame appears you are usually well past the temp required to melt the wire shielding.
Interesting problem however....I have never know Toyota wiring to light up unless someone has fiddled with it. I would be interested to know exactly what the problem is.
And just to clarify, don't drive it...Small electrical fires can get out of hand VERY quickly.
Old Dec 12, 2009 | 10:24 AM
  #29
^^^^ What he said^^^ time for a new wire loom
Old Dec 12, 2009 | 04:11 PM
  #30
RatLabGuy's Avatar
So nobody has asked the obvious question here.
Where is the smoke COMING FROM?
find out exactly. Since you don't seem to be horribly freaked out by it starting... let it idle and just watch closely and ifnd the origin.
That's a good place to start looking.
Old Dec 12, 2009 | 04:27 PM
  #31
gary96360's Avatar
a little while ago my headlights wouldnt turn off and the high beams stayed onn. so i had to unhook the battery everytime i wanted the lights off. so i went to the wrecker and got a new switch for the lights
Old Dec 13, 2009 | 03:19 PM
  #32
toyotabull's Avatar
I had that same problem last year, turns out I had water in the headlight relay and if I parked at an incline my lights would stay on or just come on in the middle of the night and set off the alarm
Old Dec 13, 2009 | 07:03 PM
  #33
Both your incidents did not involve fire however...a broken switch/relay and a hard short are two different things
Old Dec 13, 2009 | 11:22 PM
  #34
vital22re's Avatar
totally a bro
unbolt the fuse box from the fire wall and pull the plastic cover off the bottom. Its really easy to do. And it exposes the buisness end of the fuse box.
LittleUgly
15
Jan 2, 2020 01:30 PM
Alexdosdall
Dec 10, 2017 05:48 PM
primordialbeast117
Dec 19, 2015 12:23 PM
shredder4286
Oct 1, 2015 01:09 PM
bradahman
Oct 1, 2015 09:24 AM
