Would bigger wheel cylinder bore cause more rear braking?
Old Sep 30, 2024 | 11:05 AM
Jose Pena's Avatar
5 Year Member
Hey guys im rebuilding the rear drum brakes on a 89 v6 pickup. The rear wheel cylinders were both different sizes. Im guessing previous owner accidentally miss matched the rear cylinders. Now im not sure which bore size it originally had.
single rear tire and the vin says 1/2 ton.
it has F18Q front calipers and its an extra cab
Based on this info from rock auto im leaning on getting the bigger bore.
Would a slightly bigger rear bore cause any issue?
Would the rear grab more than the front?
Old Sep 30, 2024 | 12:31 PM
Melrose 4r's Avatar
5 Year Member
I’m not sure but i would guess that if the cylinder is larger in volume and the master is pushing the same amount of fluid, there would be less movement at the wheel cyl.
Old Oct 1, 2024 | 09:48 AM
Jimkola's Avatar
YT Community Team
5 Year Member
I'd think it'd be easier to just get the size that Toyota matched with the existing system. That way you don't have to worry about the master cylinder being under-sized, or making any adjustments to the proportioning valve. The vast majority of the actual braking is the responsibility of the front brakes. The rear brakes just makes sure the back of your vehicle doesn't try to pass up the front when braking, especially in turns.
Old Oct 1, 2024 | 03:46 PM
Jose Pena's Avatar
5 Year Member
Thanks for the reply. As of right now i have confirmed i have a double diaphragm power booster. I also have a 1inch master brake cylinder. It also has the bigger calipers up front the F18Q as well. I think the 15/16 wheel cylinders would be the better choice. I'll report how it feels after the install.
Old Oct 1, 2024 | 07:31 PM
toyoda addict's Avatar
Aisin/Advics wheel cylinders
7/8" 4cyl WCT-007
15/16" V6 WCT-027
1" FJ60 WCT-011
Old Oct 2, 2024 | 11:30 PM
Jose Pena's Avatar
5 Year Member
7/8" 4cyl WCT-007
15/16" V6 WCT-027
1" FJ60 WCT-011
I bleed the whole system. Lots of bubbles on the new wheel cylinders. After bleeding the system in order from furthest to closest. Do I need to bleed the load sensing proportioning valve? Ive never touched it before.
Old Oct 3, 2024 | 06:51 AM
Jimkola's Avatar
YT Community Team
5 Year Member
It is recommended. When i took my LSPV apart I was shocked with how much sediment and other build up was in it.
Old Oct 3, 2024 | 01:55 PM
2ToyGuy's Avatar
Dirty or not, it still needs to be bled out. Last.
Chances are good however it'll be full of crud. Take it apart and clean it real good, reinstall, and bleed it out, just like any other brake cylinder. But no matter what, bleed out the LSPV after all the others.
Pat☺
Old Oct 3, 2024 | 06:40 PM
Melrose 4r's Avatar
5 Year Member
The LSPV can get frozen up. To confirm it’s operational, Unbolt the cross rod and drop it down. It rides against the plunger of the valve. When someone pushes your brake pedal you should see the plunger moving in and out of the valve body.
Old Oct 4, 2024 | 06:24 AM
osv's Avatar
osv
1" FJ60 WCT-011
1" slave would be this one on amazon, looks like the price shot way up :-0 i've been running it for a couple of years, no problems so far:
Amazon Amazon
get some speed bleeders while you are at it:
Amazon Amazon
Old Oct 11, 2024 | 03:47 AM
OliverReed's Avatar
Thanks for the link, I will check it.
Spoiler
MichaelKLerner
Oct 12, 2023 02:20 PM
thewanderlustking
Feb 25, 2022 08:48 PM
richardashe
Aug 18, 2021 02:04 AM
carman350
Sep 24, 2011 06:51 PM
mjfab
Feb 15, 2006 09:40 PM
