wore out alternator
Old May 22, 2015 | 06:00 PM
greaseball's Avatar
wore out alternator
my alternator stopped working the other day so i took it out fixed the wiring cleaned the alternator,(it was covered in oil) the only thing i found wrong with it was the slip rings were wore out about half way through. i can go online and get new slip rings for about 5.00 bucks. every time i go to the wrecking yard the alternator is missing. damn. the truck is an 88 with a 22r motor and the alternator is the original. i rebuilt the motor ,put new clutch in,got it running ,the only problem i have is if you leave it for a day it won't start unless you give it some ether then i fires right off,i only have about 1 or 2 miles on the rebuilt motor so i will probably check the torque in the bolts and reset the valves. i would like to put ac back in but i need the compressor and brackets,and condenser up front but that is a luxury not a need, of course while i am dreaming i will put cruise control in too.
Old May 23, 2015 | 12:48 AM
wyoming9's Avatar
Red face
Alternators and oil do not mix well I hope you have fixed the oil leak problem!!
Paragraphs are your friend it makes reading so much easier!!
Old May 24, 2015 | 10:28 AM
chuckross1957's Avatar
I don't know if you have power steering, but it seems to be a common problem for the hose that goes to the reservoir to start leaking. Since the power steering pump is over the alternator, a leaking hose might drip on to the alternator. But if you don't have power steering the oil must be from another source. My old alternator was covered in dust, I assumed the dust was from the worn brushes in the alternator.
Old May 24, 2015 | 11:47 AM
greaseball's Avatar
it was leaking from the timing cover. the engine was wore out so i just rebuilt it.
Old May 24, 2015 | 12:29 PM
swampfox's Avatar
The brushes could be worn or sticking ,the diode pack could also be bad. I was told by a Toyota tech that you can check the diode pack with a volt ohm meter. Unhook all the wires from the alt then check continuity from the battery post to the case and switch the leads and check again ,there should be continuity one way but not the other.
shooter86314
Jan 7, 2016 07:05 AM
Chicken12
Oct 14, 2015 03:54 PM
fountain
Sep 28, 2015 03:04 AM
SCZIG
Sep 20, 2015 09:00 AM
scheuvront1993
Sep 17, 2015 06:17 PM
