Won't go into park!
Old Aug 16, 2019 | 08:15 AM
barnlofter's Avatar
Won't go into park!
!993 one ton automatic will not shift into park. Recently replaced Ignition Switch Auto Column Shiftier housing. I do not know if it was shifting before R & R. Just got her running!! Everything looks good. Just don't know where to look.
This is the Ignition Switch Auto Column Shiftier housing
Old Aug 17, 2019 | 12:03 PM
barnlofter's Avatar
Got her in Park
It looks to me like the brace on the steering column is bent down. It doesn't keep the shift column high enough. Works perfectly when I hold it in position. The image below shows the shift column in foreground. and two hold where the bolts go to hold the shifter up.
Old Aug 26, 2019 | 05:20 PM
barnlofter's Avatar
Took off steering column and straighten pad for column. Works great! This has been a learning experience. The key will not activate the starter. Just took off the NSS. Checked and no continuity anywhere. Took apart and the springs and contacts (2) had come unlodged. Stretched springs and replaced contacts and now continuity is to specs. I got the idea from this guy. Hope to install and check to see if we will crank from key!!
Here's what I started with.
OldSteve
Apr 26, 2022 01:04 PM
Up&Down
May 27, 2013 06:45 PM
DanStew
Jan 30, 2011 03:21 PM
VoxMan
Apr 28, 2007 04:53 AM
mkodish87
Jun 13, 2005 05:23 PM
