Wobble in Front end
Old Oct 25, 2006 | 05:27 PM
MAXIMUS1968's Avatar
Wobble in Front end
I just had a new set of tires put on and also had the front end lined up today, its a 94 Toyota 4x4. I can still feel a wobble when going in curves say running around 60- 70 mph, Steering Stabalizer Shock, wheel bearings???? Any ideas?
Old Oct 25, 2006 | 05:30 PM
dogman's Avatar
How's the idler arm?
Old Oct 25, 2006 | 05:35 PM
The one off the IFS? It seemed to be ok
Old Oct 25, 2006 | 09:37 PM
Elvota's Avatar
Jack up the front and try to wiggle. How's that for tech help? :bounce2:
Just flex the wheels, feel for bearing play, bushing wear, check the brakes for drag, pad wear, noise, movement.... might find it helpful to try one side at a time.
And I agree with Dogman about checking the idler arm. There are plastic bushings in the housing that can be replaced cheeply and easily if you find play there.
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
jasonty
41
Dec 23, 2018 01:00 PM
Sep 4, 2015 09:27 AM
Daneums
Aug 20, 2015 05:36 AM
