Why are the OEM Denso oil filters so cheap?
Old Sep 6, 2020 | 12:50 PM
old87yota's Avatar
I still don't see any real world benefit of using a bigger filter than specified (in this case, the 90915-YZZD1).
The specified filter should last 10,000 miles under "normal" use. I change my oil every 3,000 to 3,500 miles with a new filter, so I don't worry about needing any extra filtering media.
If your engine is in good condition, there should be no need or useful benefit to a larger filter.
If more filtering media is needed, you have bigger problems with your engine than just a filter.
Old Sep 6, 2020 | 03:40 PM
Co_94_PU's Avatar
More oil volume!
Old Sep 6, 2020 | 03:43 PM
old87yota's Avatar
Originally Posted by Co_94_PU
More oil volume!
Sure, I guess....
Old Sep 6, 2020 | 04:52 PM
Blueman's Avatar
More oil volume is a benefit (albeit a small one), and yes, the more filter area is a benefit. In my case the FJ calls for D3 and the 22RE calls for D1. If the D1 is fine for the 22RE, why not for the FJ? Likely Toyota engineers decided that more filter media was beneficial, so for me, I simply use D3 for both as it makes my life easier and there's no downside to the larger filter on the 22RE.
Old Sep 6, 2020 | 08:46 PM
  #25
Co_94_PU's Avatar
We're kind of off topic and down the rabbit hole here.
More filter area gives a reduction to pressure loss due to the volume to surface area.
A higher oil capacity gives a slower temperature transition rate, IE more stable temperature.
My RTE has a remote filter, this gives me an extra quart of oil capacity. It also runs the largest filter I can readily find which gives me another half quart. The end result is something like 30-35% extra capacity, not counting the turbo oil line (which is larger than stock by about 200%)
This is a significant amount of heatsink.
The extra pint of oil (from the larger filter) is the difference between 4.5 and 5 quarts. (~=10%)
Old Sep 7, 2020 | 01:15 PM
  #26
swampedout's Avatar
5 Year Member
Im enjoying this but I agree, oil related threads have serious legs on them.
Anyone got opinions on Fram filters?
Old Sep 7, 2020 | 01:21 PM
  #27
Blueman's Avatar
I'd like them better if they weren't orange! They make my Toyota think I'm trying to force fit Chevy parts into them!
Old Sep 8, 2020 | 09:34 PM
  #28
Jimkola's Avatar
YT Community Team
5 Year Member
imho, As long as the 22R# filter has a anti drain back valve and the owner replaces it at proper intervals it’s a good filter.
i loved the filter location on my 2005 Tacoma. My 2017 Tacoma just bites.
Phat Ham
Feb 5, 2007 03:42 PM
kdawghuntnfish
Sep 13, 2006 04:49 AM
enutter
26
Aug 30, 2005 01:07 PM
