Why is my oil light flickering and 4runner overheating
Old Jul 11, 2012 | 09:50 AM
sms3xs11's Avatar
So I just replaced my head gasket on my 97 4 runner v6 and had the heads resurfaced it seemed to be running alright until I would apply my brakes and my oil light would start to flicker and now my car is overheating. The oil is fine and the radiator seems to be fine but why is my car overheating can someone please help I don't want to drive around in 100degree heat blasting my heater but I'm terrified I will blow my head gasket again
Old Jul 11, 2012 | 09:58 AM
abecedarian's Avatar
Did you replace the thermostat? If not, it could be stuck partially open.
Did you change the oil? If not, coolant could have entered the crankcase and diluted / thinned the oil.
Old Jul 11, 2012 | 11:02 AM
James Woods's Avatar
^ That and possibly your timing is off so the oil light may be coming on because the engine is about to die at stops.
zd92655
Mar 6, 2022 12:58 PM
Team420
Jan 12, 2021 04:57 PM
JF9243176
Oct 8, 2017 04:21 AM
the1998sr5
Oct 19, 2016 12:48 PM
atticus
7
May 26, 2002 12:14 PM
