Why does A/C cut out at idle?
Old Jun 5, 2008 | 06:49 PM
abecedarian's Avatar
go back and look at https://www.yotatech.com/forums/f116.../#post50845429
Old Jun 5, 2008 | 07:47 PM
4Crawler's Avatar
Originally Posted by 94svt50
Checked it out today, at idle speeds the compressor clutch is cutting out. If you rev it up just a bit and it kicks on. I tried adjusting the vacuum screw in the above photo but it made no difference, no mater which way I turned the screw. So, I just turned up the idle speed at the throttle body to keep the a/c on. Any reason why adjusting the vacuum screw would not work?
There are two adjustments as I described earlier. The idle up valve adjusts the idle speed and the A/C Amplifier knob adjusts the cutout RPM. They sort of work in concert, the A/C Amp says if RPM > cutout then let the A/C turn on. And if the A/C is on, open the VSV that feeds the idle up valve to boost the idle speed. But if RPM < cutoff, turn the A/C off. Adjust the "RPM" knob on the A/C Amplifier, that is located behind the glove box.
Old Jun 16, 2012 | 10:33 AM
edeslaur's Avatar
Here are the steps I followed to get mine working
Here's a shot of the AC Amplifier above the glovebox. Thanks, 4Crawler. I have no idea what I'd do without your posts. BTW, starter contacts completely solved my starter issues, so I kept the rest out of respect for all your posts!! (it's just a few cents, but it's the time you're saving, man!!)
stock87yota
Jul 31, 2015 10:08 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
jake_v
Jul 22, 2015 03:17 PM
jackiebrownia
Jul 20, 2015 09:02 AM
bryan34w
Jul 6, 2015 05:53 PM
