Where's the Fuel Filter? '89 4runner V6
It's raining outside and she's parked in the mud. I can't see anything from on high. Would be cool if t was on the frame and not hidden under the manifold. -- Matt
PS It's my first 3vze powered vehicle.
Thanks everybody. You have given me what I hope is good news (that it's not buried under the manifold). BTW I have Toyota factory manuals for both the 4runner and truck for '89. I didn't see anything on the fuel filter in there. -- Matt
I bought the 4runner in need of some work. It's running pretty bad, so I'm trying to eliminate all the easy stuff, like cap & rotor, filters, compression test, vacuum test, timing, TPS, AFM, etc. If I had a fuel pressure tester I'd run the test; for now I'm replacing the filter. BTW> Autozone will sell a tester for around $150.00 and the issue a refund when the tester is returned. I'm debating (mostly with myself) whether I should go that route or buy this one for $45.00 and keep it. -- Matt
TURBOrunnerNM
Jul 22, 2015 11:01 AM
