Where is this transmission plug? (pics)
Old Mar 31, 2013 | 12:11 PM
Parasitick's Avatar
Traditionally (based off the haynes book) the plug should be at the bottom with a bolt in place clear as day.
The arrow where I THINK is the plug is a (I believe) 22mm bolt. Is this right? Any clues?
Attached Thumbnails Where is this transmission plug? (pics)-20130331_110421.jpg
Old Mar 31, 2013 | 12:33 PM
Co_94_PU's Avatar
Just exactly which plug are you looking for, and on which transmission?
The fill is on the side and the drain is on the bottom. In my case they're kinda hard to mis, both in the center just forward of the backup lamp switch.
http://personal.utulsa.edu/~nathan-b...31componen.pdf
Old Mar 31, 2013 | 03:30 PM
Parasitick's Avatar
Sorry, just assumed everyone knew I meant the drain plug. It's SUPPOSED to be on a 6 cylinder 4wd 94' 4runner (I suspect this isn't the original transmission). Manual.
Old Mar 31, 2013 | 04:31 PM
ThatGuy1295's Avatar
Thats the drain plug. The fill plug is up above that one. Same idea as the differentials.
I think thats what your asking And from what you have shown thats an R150F trans which is the correct trans for your 4wd 3.0 4runner.
Old Mar 31, 2013 | 04:33 PM
Probably goina have arguers about this saying oh its an R151F. So heres your link.
http://en.wikipedia.org/wiki/Toyota_R_transmission
Old Mar 31, 2013 | 05:56 PM
Parasitick's Avatar
Yeah, that's what I was askin about... good to know its the original too (and not good lol). So 21-22MM bolt sounds right? I just thought it was odd. Like I said, in the haynes book it had a picture underneath showing the bolt directly on the bottom of the transmission for a 4wd version. I tried to loosen it up before posting but it was pretty firm and I didn't want to screw with something that might have a very negative effect.
Old Aug 1, 2014 | 09:29 PM
Cdn-wilderness's Avatar
Bump
is the fill plug for the R150f the funny bolt above the drain?
or the plug on the opposite side of the tranny?
smthwsn357
May 1, 2024 07:28 AM
Sep 4, 2015 09:27 AM
Poncho0206
Jul 10, 2015 06:21 PM
bryan34w
Jul 6, 2015 05:53 PM
