When CEL is on the engine is lugging
Old Aug 9, 2006 | 05:04 PM
jjenks0's Avatar
I rebuilt the heads on my 3.0. I think it was running on only 3 cylinders. Since I have had it back to gether the CEL is coming on. the engine seems to be lugging. There has been a time or two when the CEL was off and the engine had great accelaration. I pulled the codes a week ago and they said 25. since then I have had the intake off trying to fix a vacuum leak. In the process I broke the sensor on the back of the block that has the two blue post coming out of it. I found one at a junk yard and put it back together. Now I get a code of 15 and 24. I do not even think there is a code 15. I am going to pull out the O2 sensor and try to clean it and see if that helps. Any ideas what those codes are?
Old Aug 9, 2006 | 05:20 PM
Saint_Berzerker's Avatar
Not sure about the V6, but I know that the CEL on mine (until I got if fixed), will retard the timing....causing that sluggish feel...especially under acceleration and going up hills.
Gotta get rid of the CEL by fixing whats wrong.
Old Aug 9, 2006 | 06:41 PM
jjenks0's Avatar
What was wrong with yours?
Old Aug 9, 2006 | 10:37 PM
Guardian_Saint's Avatar
As for the code, code 15 has no code on its toyota manuel so check what is the exactly code it giving, about code 24 it is, System Effected *Intake Air Temperature Sensor Signal - Possible Cause *Intake Air Temperature Sensor or circuit, ECU.
Old Aug 13, 2006 | 07:15 PM
My engine light was for the knock sensor. But I think any code will retard your timing.
Gotta get that code out or it'll never run or time right.
Old Aug 14, 2006 | 09:50 AM
jjenks0's Avatar
The shop says it is my knock sensor, i put a new wire on it but they think maybe i pinched it hopefully will get it fixed tomorrow
Old Aug 16, 2006 | 06:20 PM
jjenks0's Avatar
It was the knock sensor. Also I figured out that my vacuum leaks could have been from the injectors not being seated good enough. My mechanic say they should always be given a turn while being inserted. Preliminary gas milage is showing around 16.
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
v_man
Jul 23, 2015 04:01 PM
Sandman
Jul 14, 2015 12:36 PM
Roger Borba II
Jul 9, 2015 05:05 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
