Wheel "wobble"
Old May 16, 2006 | 06:41 PM
tc's Avatar
tc
Wheel "wobble"
Need some help on what to search for ...
When I was putting on the 'wheeling tires, I noticed the driver's side front wheel "rocks" when pushed at 12 and 6, but not at 9 and 3.
Balljoints? Wheel bearings? Tie rods?
Old May 16, 2006 | 07:00 PM
ChickenLover's Avatar
If you are getting a loose feeling (like your lugnuts are loose), your bearings just need to be repacked. A bad ball joint would require a lot more pressure to notice the play (you'd need to pry up from underneath your tire with a bar).
Tie rod play would be at 9 and 3.
Old May 16, 2006 | 07:08 PM
tc's Avatar
tc
Correct - it rocks under hand pressure, kinda like the lug nuts were backed off.
Old May 16, 2006 | 07:25 PM
Been there, done that many times. Repack the bearings.
Old May 17, 2006 | 09:40 AM
Toyopnoy's Avatar
Sorry to hijack, will Lithium based grease be good for this?
Old May 17, 2006 | 10:49 AM
kyle_22r's Avatar
yep, i like using a moly grease myself. marine grease also works very well!
Old May 21, 2006 | 09:23 AM
tc's Avatar
tc
I finally found the instructions in the online FSM ... is this really something I should do myself or would it be worth it to pay someone? Looks like there's not a whole lot too it, but seems kinda finicky about drag and torques and stuff...
The truck has about 190k miles and I wheel pretty frequently. Would it be a good idea to just replace the bearings while I'm in there?
Old May 21, 2006 | 02:29 PM
eric-the-red's Avatar
Definitely not, you need a good high temp wheel bearing grease. With disc brakes the hubs get hot and lithium or marine grease will melt and run out. Save those for areas that get lots of water but not much heat.
Old May 21, 2006 | 02:35 PM
I used this write-up when I repacked mine. It's not that difficult. It also has instructions for replacing. To replace or not depends on how the bearings feel when you get them out. I don't think they are very expensive to buy, so if you have doubts about their condition you might want to put new ones in.
http://www.off-road.com/toyota/wheel_bearing.html
Old Jun 3, 2006 | 05:39 PM
tc's Avatar
tc
Going to (finally) repack the bearings tomorrow - any other last minute input?
Old Jun 3, 2006 | 06:28 PM
lVlr_87's Avatar
36mm socket for the spindle nuts. Use Moly grease.
Old Jun 3, 2006 | 08:09 PM
LOCKnGO's Avatar
Ha Ha me too.. The last time my bearings were loose that retainer that holds the spindle nut in place decided to shed its tabs. I barely made it home.
Old Jun 3, 2006 | 10:32 PM
Asha'man's Avatar
2 1/4" works too. I got mine at Sears for about $22.
Brian
Old Jun 3, 2006 | 11:26 PM
Brian
It's 2 1/8" and/or 54mm.
Old Jun 4, 2006 | 12:27 AM
TNRabbit's Avatar
Don't forget to get new seals...
Old Jun 4, 2006 | 10:35 AM
Lysmachia's Avatar
He said use Moly grease.... LOL - How fitting!
Old Jun 5, 2006 | 11:24 AM
tc's Avatar
tc
OK, I FINALLY found a brass punch, (Sears, local big hardware store, Advance, Autozone, Tractor Supply didn't have one or even any brass stock I could use) so I think I have everything:
2-1/8" socket + 3/4"-> 1/2" drive adapter
1/2" drive torque wrench
3/4" brass punch
Inner oil seal
inner bearing
inner race
outer bearing
grease
I forgot to get the spindle lockwasher. I'm going to see if anywhere has it in stock after work - the FSM says it's a nonreusable part, any thoughts?
Doesn't look like there is an outer seal - is that correct?
Old Jun 5, 2006 | 03:35 PM
runethechamp's Avatar
I've reused mine a couple of times. Don't know if it's smart though, but I haven't had any problems yet.
And as far as I remember, no outer seal. That part is sealed off with the ADD flange or your manual hubs.
Old Jun 5, 2006 | 06:36 PM
tc's Avatar
tc
Did it tonight, took 2.5 hrs, including having to go get the neighbor to help me bleed the brakes.
One little hint - clean ALL the grease out of the hub and you'll see little notches where you can get your brass punch in to knock the races out easier.
Old Jun 8, 2006 | 06:13 PM
LOCKnGO's Avatar
Sweet
kouki420
Sep 2, 2015 11:42 AM
NCRidgeRunner
Aug 13, 2015 04:11 AM
Up&Down
Aug 5, 2015 06:20 AM
Luvmeye22re
Aug 4, 2015 03:53 PM
skoti89
Jul 6, 2015 07:45 PM
