Wheel seal issues
Old Sep 5, 2012 | 05:45 PM
Weston_Duyck's Avatar
Wheel seal issues
My truck started leaking gear oil out of what I thought was a bad wheel seal so I replaced it. While in there I looked at my bearing and it seemed fine but the rear axle started leaking in the same spot again. Any ideas?
Old Sep 5, 2012 | 05:55 PM
85TurboRunner's Avatar
Maybe you messed up the seal when putting the axle back in?
Old Sep 5, 2012 | 06:11 PM
TNRabbit's Avatar
There are two seals; did you replace both?
Old Sep 5, 2012 | 06:43 PM
Well the weird thing is that I replaced it almost 3 weeks ago and it just started leaking today. And where is the second seal? Axle side next to the drum?
Old Sep 5, 2012 | 06:50 PM
I'm guessing he means the rubber o ring that goes on the end of the axle housing.
When I replaced mine a couple months ago I just used RTV in place of the o ring and I haven't had any issues.
With or without that o ring if you're leaking gear oil the seal is bad.
Old Sep 5, 2012 | 07:18 PM
Alright I got it...well I'll dig into tomorrow and take a look
Old Sep 5, 2012 | 07:29 PM
TNRabbit's Avatar
Old Sep 5, 2012 | 09:34 PM
Grego92's Avatar
Not exactly sure what seal you already replaced, but I believe there are two seals and the o-ring that could be replaced if you were to remove the axle.
This is for a 92' pickup so yours may differ:
42311A - Part No. 90310-50006 in the diagram is a seal that is tapped into the axle housing (green arrow area in second picture). I think this is sometimes referred to as the inner seal.
42311E - Part No. 90313-48001 in the diagram (and in TNRabbits photo) is known as the outer seal.
I just did a differential leak repair and drum brake job, and purchased both of the above mentioned seals to do some preventive maintenance while I was in there. Luckily my o-rings were fine because I forgot to purchase those. I only replaced the inner seal because to get to the outer seal it required some press work from a shop.
If it's the inner seal that is leaking, did you use oem seals from the dealer? did you put some grease around it to help tap it in and so it goes in straight and flush? I admittedly screwed one up while tapping it in, and had to run to the dealership to get another one.
Old Sep 6, 2012 | 10:56 AM
I replaced the inner seal with a Timken seal. And yes lubed it up and tapped it in straight. I didn't even know about the o-ring so I don't know the condition of that.
Old Sep 6, 2012 | 11:44 AM
TNRabbit's Avatar
O-ring is around the outside of the axle tube, behind the hub:
Old Sep 7, 2012 | 03:53 AM
nobb's Avatar
Use a genuine Toyota seal 90310-50006. This is the newer design with a different rubber seal design that many of the aftermarket ones do not have. Also make sure you do the grease test to see that the seal is making contact with the retainer.
The outside O-ring keeps water and debris out from the assembly, but it is the inner axle seal which keeps the grease inside the axle housing.
mskalmus
May 28, 2017 07:51 AM
Iceman4193
Jul 15, 2015 04:48 PM
andrewtexas123
Jul 14, 2015 04:29 AM
cars-guy
Jul 11, 2015 07:51 PM
skoti89
Jul 6, 2015 07:45 PM
