What is this wire for??
Old Aug 5, 2014 | 02:23 PM
toyotasaurus's Avatar
I just picked up this 1991 4Runner (3.0v6 5speed) for my oldest who just turned 16 and am going through it fixing what's wrong before she starts driving it. While looking around the engine compartment I discovered this wire on the passenger side of the engine. Anyone know what this is for??
Old Aug 5, 2014 | 02:31 PM
Gevo's Avatar
A/C magnetic clutch, pretty sure.
Old Aug 5, 2014 | 02:36 PM
OK, next question.....where is it supposed to hook up to??
I'm guessing that it goes straight to the compressor. Will have to look at that tonight.
Old Aug 5, 2014 | 05:00 PM
Gevo's Avatar
It goes to wiring harness, then to A/C amplifier
http://personal.utulsa.edu/~nathan-b.../2aircondi.pdf
However, before you do any work, check to see if the magnetic clutch is working, so you know if it is worth chasing for you or not. Jump this wire to a 12 volt source, see that center part of ac compressor pulley starts to spin. If it does, don't leave it for more than a couple seconds. I don't think it's healthy for the compressor to run dry.
Old Aug 7, 2014 | 08:56 AM
Found the other end of it last night so I'll hook it up and check things out as soon as I get the knock sensor replaced.
Old Aug 7, 2014 | 11:05 AM
kcaudill's Avatar
80Truck
Oct 12, 2025 07:25 PM
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
ToyoToler
Aug 8, 2015 08:43 AM
Daneums
Jul 28, 2015 11:57 AM
TDonkey
Jul 26, 2015 10:14 AM
