What are these gaskets for?
Old May 4, 2015 | 10:46 AM
ditypup's Avatar
It seems that in every 22R(E) full rebuild gasket set I end up with these as left overs. What are they for?
Old May 4, 2015 | 11:04 AM
wyoming9's Avatar
Red face
Could very well be something for engines outside the USA
These gaskets might be used on another engine only ours does not need them
Old May 4, 2015 | 11:29 AM
fierohink's Avatar
Based on shape, I would say plenum gaskets for a different style intake. Not sure what other application they would come from.
Old May 4, 2015 | 03:23 PM
ditypup's Avatar
I was thinking a different intake plenum or under the valve cover.
Old May 4, 2015 | 05:30 PM
slacker's Avatar
^^^ yep ... they are for the PCV cover on the underside of a 22R# series valve cover
Old May 4, 2015 | 05:50 PM
ditypup's Avatar
Any idea how to get the PCV cover off?
Old May 5, 2015 | 04:49 PM
slacker's Avatar
it's bolted on .. just undo the bolts
Old May 5, 2015 | 05:09 PM
ditypup's Avatar
wow that's cool. However all three of mine are riveted.
Old May 5, 2015 | 05:32 PM
slacker's Avatar
ahh , then if your insisting on doing it ..
like the 5vzfe VC's I powder coat , you'll need to "grind" the rivets off .. I use a die grinder , and trim the mushroom part of the rivet , leaving the post .
I then use a silicone gasket material to "glue" them back on when I'm all done with what I'm doing ..
Old May 6, 2015 | 09:55 AM
ditypup's Avatar
this is what all mine look like
Old May 6, 2015 | 04:25 PM
slacker's Avatar
so why do you want to take the plate off ? you really don't ever have to remove this , unless your sandblasting the cover or something like that ..
Old May 6, 2015 | 04:45 PM
ditypup's Avatar
If a person could replace the gasket easily then why not? But, evidently that is not the case for my covers. Wonder why Toyota made covers with removable PVC baffles and some without. Maybe it was a production and cost thing, who knows. At least now I know what the extra gaskets are for. ;-)
Thanks all.
_Nicco_
Sep 21, 2015 03:06 PM
Obmi
Sep 16, 2015 02:13 PM
bootscootboogie
Sep 5, 2015 05:57 AM
Scotto6591
Sep 3, 2015 07:38 PM
scottyg486
Jul 19, 2015 05:34 PM
