what size of tire for my yota
Old Jul 11, 2013 | 02:40 PM
whitecollarredneck's Avatar
You should be able to clear them. You figure you're adding 2" of tire so if you can clear another inch on each side of your fender you'll be fine. Kiss your mileage and power goodbye though.
Old Jul 11, 2013 | 06:11 PM
RSR's Avatar
RSR
Yep, definitely make sure you run the numbers and do your research before you upgrade your tires. That's definitely part of why I've stayed w/ 31s.
I'm pretty sure the 5.29s are the largest drop in gears for your current differential/axle setup. But you're probably going to need to change out your front end anyways with you current setup, so just the add'l cost of your backend I guess.
Your 4cyl tranny and a few other driveline components are less robust than the V6 options, so will probably fail quicker/consider upgrading pre failure too.
Look here for parts/pricing options on what you'd like to do (others too but a good baseline part availability/pricing resource): http://www.marlincrawler.com/
Look here for info on stock diffs: http://www.brian894x4.com/Gearratiosanddiffs.html
Look here for a gear ratio calculator: http://www.grimmjeeper.com/gears.html (make sure you know/take into consideration your engine's powerline at the speed[s] you'll need the most performance)
And 4crawler has a pretty good resource on lifts too:
http://www.4crawler.com/4x4/ForSale/BodyLiftKit.shtml
http://www.4crawler.com/4x4/ForSale/DiffDrop.shtml
Old Jul 11, 2013 | 11:04 PM
bob200587's Avatar
Looks fine with the tires already on it.
Body lifts and bracket lifts suck, and you're pushing the limits as it is.
Time to SAS and upgrade a lot of drivetrain components if you want to go bigger.
Old Jul 12, 2013 | 04:16 AM
SHINE RUNNER
Guest
Posts: n/a
Remove all but the 4in suspension and cut out the fenders and get 5.29 gears and 38's and sas
Sep 4, 2015 09:27 AM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
coffey50
Jul 28, 2015 10:55 AM
Gravel Maker
RuffStuff
Jul 27, 2015 06:53 PM
Yotoder865
Jul 9, 2015 07:51 PM
