What size is lower starter bolt in 3vz
Old Jul 5, 2006 | 06:52 AM
ReneB64's Avatar
I woke up yesterday morning; went out to start my 1993 toy 4x4 ext cab and it just made a grinding noise; like the gears on the starter were not meshing. Of course, oh h***, another problem. I planned on going out today, buying another starter and replacing it, but it doesnt look as easy to get to as I thought. Reguardless, I noticed, the lower bolt on the starter was missing, hoping that is the problem, but I am looking for the correct size, not sure autozone knows, if not guess I will go to the stealer.
Old Jul 5, 2006 | 09:00 AM
ReneB64's Avatar
anyone?
Old Jul 5, 2006 | 11:16 AM
eric-the-red's Avatar
M12 maybe, it's been a while since I removed mine but I think it was a 17mm socket, which usually means an M12 thread. As for length, that's asking more than my 40something memory can handle.
Old Jul 5, 2006 | 11:59 AM
snap-on's Avatar
i can tell you its like 1.75" long (So like 45 mm or something)
Old Jul 6, 2006 | 09:22 AM
ReneB64's Avatar
Thanks Guys
Thanks Guys,
The dealer didnt have one in stock, or know the size, only part #....I went down to my local toy mechanic and had something lying around that fit, just had a hard time starting it with bolt missing, had to roll it to start...thanks again
Old Dec 13, 2021 | 10:42 AM
vatoelocoe's Avatar
you ever find the exact size bolt? my starter just fricking fell out this morning. i went to start my 4runner and it sounded like a damn sawblade was in my engine. i can move the starter around with my bare hands....
Old Jul 19, 2022 | 01:35 PM
b2sdad972's Avatar
Happened to my Sons 4Runner two weeks ago. Starter was literally hanging by the positive cable and wire harness. I can’t seem to find those bolts anywhere. Did you ever find what size they were?
Old Jul 22, 2022 | 07:43 PM
coopster's Avatar
From: exo-reality -wave if you see me; Front Range, CO
I'm about 90% sure they're M10 x 1.25. Now the length, I can't recall. Because the 3vz and 5vz are different. IIRC on the 3 they both insert from front of vehicle (and they're both about the same length?).
The 5V has one from the back, but its much shorter. Like 3 inches or something. But I really don't remember now. I do know they are the 10x1.25 I still got one in a bag, labeled. And just went out and checked it. LOL about the only dang thing I bagged and labeled.
Old Mar 10, 2024 | 05:01 PM
thedjelectron's Avatar
I am 100% sure they are both M10 x 1.25. The lower bolt that goes in from the front to the back is 40-45mm long. Don't get just any washer head bolt tho. It should be a 14mm bolt with about a 15mm washer. If you get a generic bolt from AutoZone, it's likely to be 15mm drive and too wide to fit properly. The bolt hole is pretty close to the starter body.
kgcwb44
Jan 29, 2023 10:02 AM
Sep 4, 2015 09:27 AM
Gravel Maker
RuffStuff
Jul 27, 2015 06:53 PM
whereAreMyPants
Jul 22, 2015 03:32 AM
HaydenConQueso
Jul 12, 2015 05:22 PM
