What is this part??
Old Nov 22, 2024 | 12:49 PM
Noobie29's Avatar
What is this part??
How’s it going I was hoping to see if any body knows what this cable is. I’m having trouble with my truck starting and only makes one click when turning the ignition. I’m assuming this cable is the reason why it’s not turning on
Old Nov 22, 2024 | 02:02 PM
millball's Avatar
Probably has nothing to do with your starting problem.
The engine type and photo orientation are not clear, but your item is either an oil pressure sensor or knock sensor.
Neither of these being disconnected would keep your machine from starting.
Old Nov 23, 2024 | 10:55 AM
Lifted1's Avatar
i think that is your oil pressure sending unit/sensor wire. just turn on the key and start the car and check to see if your top left oil pressure guage is functioning or not.
for your 1 click problem start troubleshooting the easiest things first.
check your battery connections for corrosion first. remove and clean the cables and battery terminals and reconnect.
Check your batter cable leads very closely for corrosion WITHIN the cables/plastic covering. overlooking this simple thing can lead to a witchhunt and lots of money you dont need to spend.
Have your battery tested
if all of the above check out, then remove your starter and take it down to local AutoZone/Orilley's/ Napa, etc. i think they all test batteries and starters for free.
Old Nov 26, 2024 | 08:04 AM
slacker's Avatar
yup , its for the idiot light on the dash , oil pressure light .
Old Dec 4, 2024 | 08:28 PM
HaydenGreer's Avatar
How is everything now?
And where can I buy free essay examples? I’m searching for a reliable site that offers a variety of topics. If you know a good platform, please share the link or suggest one. Thanks in advance!
Ralphthe4runner
Mar 30, 2020 10:52 AM
Erich Stein
Apr 2, 2019 07:14 AM
redtacoma31
Feb 18, 2014 09:03 AM
evileyejones
May 9, 2011 08:09 AM
green9422re
Dec 28, 2010 11:46 PM
