What part is this?
Old Jan 29, 2007 | 02:51 PM
alankenji_84's Avatar
What part is this?
While removing the head I accidentally broke a wire. The wire leads a to cylinder with a a snap clip just in front of the oil filter. It has a rubber boot about 1.5" indiameter that goes over the connection. I will try to post a pic later if I can. Thanks in advance for any help.
Also, any way I could possible solder the wires together while I'm waiting for the part, or would there be impedence issues? Thanks again
Old Jan 29, 2007 | 02:57 PM
JEBSR5's Avatar
Pic will help, but a guess maybe the oil sender. Should be able to solder with no problem.
Old Jan 29, 2007 | 03:35 PM
pics
Here are the pics
This is the wire with harness and dustcap
This is where the harness attaches. it clips onto the shiny brass looking connector ontop of the cylinder which is in front of the oil filter and to the lower right of that bolt. thanks by the way it is a 1992 4runner with a 3.0 V6
Thanks
Old Jan 29, 2007 | 03:36 PM
DeathCougar's Avatar
Links no worky
But you are describing the oil pressure sending unit.
Old Jan 29, 2007 | 04:12 PM
Thanks for the help
88sasturbotoy
Jan 30, 2026 01:57 PM
May 20, 2016 10:27 AM
Fundy Rider
Jul 16, 2015 01:35 AM
akaphilly
Jul 9, 2015 02:34 PM
