What kind of shocks are these?
Old Jan 22, 2006 | 04:37 PM
linuxrunner's Avatar
According to my pit marks in my tires and my G/F complaints i am in need of new shocks. i was just wondering if some Toyota genius could tell me what kind of shocks they think these are... could they be the original? Thanks.
Old Jan 22, 2006 | 04:38 PM
91Toyota4x4's Avatar
OE Baby
Old Jan 22, 2006 | 04:43 PM
Good stuff... that means that they could have over 200,000 miles on them i guess they could be shot.
Old Jan 22, 2006 | 04:46 PM
Elton's Avatar
those would be stock time to get some new ones
Old Jan 22, 2006 | 05:01 PM
Paul H.'s Avatar
Good luck getting those suckers off, lots of rust in the area.
Old Jan 22, 2006 | 05:04 PM
Elton's Avatar
ya i had fun getting mine out i used a big inpact gun and a torch to heat up the bolts
Old Jan 22, 2006 | 05:06 PM
I know it looks like rust, but i played in alot of red dirt/mud the other day. I actully have very little rust on my rig. i think 2 spots now, one on the rear bumper and some rust on that guard that is under the engine. But i am not looking forward to takeing them out as i have no impact wrench.
Old Jan 22, 2006 | 08:07 PM
trythis's Avatar
Me too, I have an 89 with original shocks, if you look close on the casing, they will have toyota part numbers, mine are actually in great shape, I doubt the original owner replaced em with OEMs so I am guessing they are OE. Go od stuff I guess.
Old Jan 22, 2006 | 10:02 PM
marko3xl3's Avatar
They are stock yes. I hope replacing will be a no-hassle job for ya.
But...holy smokes CV angle
Old Jan 22, 2006 | 11:56 PM
Bobakazi's Avatar
Definately original
Old Jan 23, 2006 | 09:52 AM
LOL, it was up on jack stands so that is why the harsh angle
Old Jan 23, 2006 | 09:56 AM
UKMyers's Avatar
Mine had OE shocks when I bought it with only 89K on them. I was absolutely blown away at the difference when I put my Bils on there. Shocks wear out so slow you never really realize they are totally toast until you replace them.
Old Jan 23, 2006 | 10:00 AM
tc's Avatar
tc
OE - mine were KYB Gas-a-just I think. I put ProComp ES3000's on, rides OK. Probably should have done Bilsteins.
You can't get an impact on the bolts you need one. Sawzall to the rescue - especially on the back upper studs.
Old Jan 23, 2006 | 10:12 AM
so bilsteins are really worth it? were is the cheapest place you have found to buy blisteins? i need 5100 right? i have an 88 runner. So hopefully new shocks will make it ride better, feels like it bottems out on every crack in the road.
Old Jan 23, 2006 | 10:21 AM
Flamedx4's Avatar
Yep, shocks will make so much difference you won't believe it. Those were probably shot 150K ago.
Are you at stock height? Look at your front bumpstops - you might BE bottoming out - they bottomed out easily when new. A little Tbar Up might help.
Bils are worth it if you have the budget, but on a stock truck anything will be an improvement. If you are mostly pavement, simple shocks from Napa or whatever give a smooth ride. The bils are a little stiff but handling will be much improved.
Old Jan 23, 2006 | 10:22 AM
UKMyers's Avatar
I got my Bils at Central 4WD. Not sure of the number just tell them what you are putting them on and they'll hook you up.
Old Jan 23, 2006 | 03:07 PM
Paul H.'s Avatar
Hint, before you try to get the upper nut off, soak it with wd-40 or something similar and then wire brush the threads to clean them up.
Old Jan 23, 2006 | 03:48 PM
90vetteman's Avatar
Those are the original shocks. An impact will take them off pretty easily. On the back, the top stud is a major PIA. Soak them good and if that doesn't work, fall back to the sawsall. I ran Rancho's on my 94 and liked the ride and the price was right.
Old Jan 23, 2006 | 04:30 PM
Elton's Avatar
well you didint say it has a lift so the heavy duty bilsteins are $269.80 shiped
if you have a 4inch lift the 5100s are $329.80 shiped all prices are from http://www.truckperformance.com/
Old Jan 23, 2006 | 04:37 PM
Kyle95sr5's Avatar
my old ranchos on my 4runner were shot. I had to cut them off with a sawzaw, it was a horrible site. cuttin off some nice expensive shocks. i replaced them with some Monroes in the front and some Monroe reflex in the rear. Made sooo much difference, not near as much body roll, and i actually feel confident when takin a corner at a higher rate of speed. Sits right there on the road, some people may not like them but for like 200 bucks for 4 shocks wiith lifetime warranties, i like um.
