What happens to unadjusted brake shoes?
Old Feb 8, 2007 | 01:00 PM
Lifelongtoy's Avatar
Question What happens to unadjusted brake shoes?
I didnt adjust my shoes all the way so my E-Brake has 25 clicks instead of the specification of around 11-17 clicks. I wont have time ti readjust for a few days. How bad is that, will it hurt anything?
Old Feb 8, 2007 | 01:11 PM
4Crawler's Avatar
Should not hurt anything. The e-brake adjustment is just in front of the gas tank, take up the slack in the cable.
Old Feb 8, 2007 | 01:19 PM
It doesnt matter that the adjustments under the wheel cylinder are not correct? Aren't the shoes gapped from the drum more than they should be?
Old Feb 8, 2007 | 01:24 PM
4Crawler's Avatar
They should self-adjust with parking brake application. However, as the shoes wear, you need to take up the slack of the parking brake cable. If the self-adjuster wheel is frozen, then yes, you may need to free it and take up the gap there.
Old Feb 8, 2007 | 01:27 PM
gonzo's Avatar
You should back off on the e-brake adjuster, then adjust the rear shoes up till they are just touching the drum. Then adjust your e-brake up.
Old Feb 8, 2007 | 08:07 PM
hockeybird's Avatar
they should self adjust. Try backing up a few times and pulling the parking brake. If that doesn't work just pull off the wheels and drums and adjust. Doesn't take long.
Old Feb 9, 2007 | 04:33 AM
thook's Avatar
You adjust it while the drums are on, though.
Old Feb 9, 2007 | 08:45 PM
PirateFins's Avatar
backing up does nothing in a Toy (your thinking GM), adjust them by pulling the ebrake until you arm feels like it's gonna fall off.
Old Feb 9, 2007 | 10:42 PM
drew303's Avatar
The adjuster could be siezed up. I had to take mine (both sides) apart and clean em and grease the hell out of em. Work fine now .
you can adjust it through a hole in the backing plate . theres a little rubber grommet that pops into the hole you have to remove.
1uzRunner
63
Nov 10, 2018 03:58 PM
old87yota
Sep 9, 2015 12:39 PM
fabing455
Sep 7, 2015 08:08 AM
Scatterbrain
Sep 3, 2015 06:46 PM
trailgoat
Aug 13, 2015 05:54 PM
