What could it be? :(
Old Jul 31, 2012 | 12:10 PM
  #41
StewsRunner's Avatar
So i'm bringing my thread up again, I before stated that my issue was solved and it was, for about a month. Now i'm back to the same old stuff, hard starts and poor idling. I can not really classify when it does it temperature wise but here are vids of my truck starting, the first one is the first, actually 2nd start of the day, i forgot to record the first but sounds pretty much the same. The second clip is what I deal with after I drive it somewhere and let it sit for a min, it happens close to every time. The only time I can start it with maybe 85% confidence is after I fill it up (after the first start that is). I know it is as simple as air, fuel and spark. I before had it hooked up to a fuel pressure gauge for about a week and pressure was all good. Spark plug wise, the spark is good, I checked the cap and rotor and they look "okay" closer to good than bad. I peaked in the throttle body and it looked okay from what I can see, I did also smell fuel, is that okay?
During start ups, giving it some gas only works about 1 out of 5 times and when it does catch, I have tried giving it gas to avoid the rough idle but the rough idle then occurs after I let off.
I have read lots of threads but I am yet to find the exact same thing so please don't tell me to "search" and once again, any help is GREATLY APPRECIATED! Thanks!!
Old Jul 31, 2012 | 05:44 PM
  #42
I have also concluded that the smell of fuel that I previously mentioned is coming from the tail pipe. So I do not think fuel is the problem, unless you classify it as too much fuel in which case it is a problem.
Old Jul 31, 2012 | 06:26 PM
  #43
bone collector's Avatar
After that much cranking.. i wonder how are the plugs??? are they fouled?? and if you smell fuel from the tail pipe im starting to think you have a spark problem. and the 3.0 distributors are know to go bad from time to time. i replaced mine and it helped my idle a bunch. just my .02
Old Jul 31, 2012 | 06:41 PM
  #44
Well the plugs are new but maybe I'll check them after a good crank like that. One mechanic suggested changing the distributor but I didn't want too with out a logical reason. I'll see about getting one at pick n pull and see what happens. Can I ask why you think fuel smell from the exhaust suggests spark? I mean I guess it make sense, with that long of a crank the fuel is doing its job but the spark is holding it back.
Old Jul 31, 2012 | 06:59 PM
  #45
lots of fuel out the tailpipe suggests to me that it has plenty of fuel but its not being completely burned. so a lack of spark is the problem in my head. im not a professional mechanic but ive turned a wrench or 2 and i slept in a Holiday Inn Express last night.....jk good luck and keep us posted
Old Jul 31, 2012 | 07:47 PM
  #46
Did it just help your idle or did your all around start get better. I know te cap and rotor play a huge roll on starting but would the distributor just help the idle or would help the start, assuming that's the problem. Thanks again man!!
Old Jul 31, 2012 | 08:31 PM
  #47
My truck does start a little bit better but I wasn't dealing with a problem like you are. My idle was slightly jumpy and was very obvious with a timing light. I would suggest you check the distributor per the FSM. Good luck
Old Aug 1, 2012 | 02:44 AM
  #48
vital22re's Avatar
totally a bro
sometimes hard starts when warm are the precurser to a failing headgasket. Being its a 3.0, good luck.
Old Aug 1, 2012 | 09:17 AM
  #49
Is there any way of testing the head gasket or would I have to just break down and rebuild it completely? And can a head gasket go bad for 8 months shouldn't I see a failure by now?
