Welding a receiver to an Addicted Offroad frame reinforcement Kit
Old Nov 28, 2017 | 06:31 AM
89fourrunner's Avatar
Has anyone done this? Addicted sells a frame reinforcement kit for their bumpers in case you plan on mounting and using a winch with their bumpers. I want to weld it on and then weld a hitch receiver to the center of it. This way I can run a winch and the stock bumper. I will also be able to take it off and on whenever I please (with a winch hitch mount kit).
Has this been done? Anyone have pictures if it has been done?
Thanks.
Old Nov 28, 2017 | 07:17 AM
dropzone's Avatar
Fossilized
seems like the process would be the same as the frame reinforcement kit
Old Nov 28, 2017 | 03:26 PM
muddpigg's Avatar
Might wanna fab something with a bit re-enforcement for loads. That re-enforcement that addicted sales is intended to prevent bolts from pulling through factory crossmember.
Old Nov 29, 2017 | 12:04 AM
wyoming9's Avatar
Red face
Comes down to the skill of the Fabricator!!
Then just what do you plan to drag around .
Is this going in the front or rear??
I most often use my winch on the rear .
The trick with the front is keeping it as tight to the front of the truck as possible
